post-15058462
Post #45,721 of 50,599
mikp
Out of those the ZS10 Pro is the best overall sounding imo. If you want something a bit cheaper the ZSN Pro is another one of the latest designs, I guess they have a great sound to them too. I haven't tried them personally but, they have he same shell has the ZS10 - just 2 drivers instead of 5 per ear.
seems I have the b - pin of the apt-x hd cable, so dont know if its compatible with the zs10 pro. See they sell a c pin also thats compatible. Seems the cc c10 is supposed to work with it, I see now they use the 2 pins that stick out.
post-15058494
Post #45,722 of 50,599
Podster
Middle Earth
Middle Earth
That's the one thing I've always liked is those who like the ZS5 V1 really love them but pretty much that happens with one model or another for KZ lovers:wink:
post-15058502
Post #45,723 of 50,599
revand
That is a pretty funny pairing. The headphone cost doesn't even probably cover the tax on the DAP
Yes I agree :)
I was reviewing the Kann on my blog.
My KZ ZSN was new and I made a try.
But these moments show how good is the KZ ZSN
Usually I use it with a Fiio BTR3.
Reactions: billbishere
post-15058794
Post #45,724 of 50,599
Veyska
In front of my computer
Was gonna' post commenting on that and then I load the next page and see you already had. :p Don't have the ZS10 Pro (yet, at least, but I'm in no huge rush because...) but I do have the CCA C10 and it is quite nice and I can heartily recommend it as a solid all-rounder. :)
post-15058819
Post #45,725 of 50,599
mikp
would not want to buy another apt-x hd for just the c pin. If b pin would work on the zs10 pro, I would get that
post-15058828
Post #45,726 of 50,599
Veyska
I think it would technically work... The protruding bit on the Z10 Pro would still be protruding though, instead of safely inside the cable's end, and thus more vulnerable to being damaged (and also possibly messing with the fit/positioning a bit).
post-15059278
Post #45,727 of 50,599
RikudouGoku
Sweden
Sweden
Website
docs.google.com
Is There any other iem that is similar to the zs7 in sound but with a shape like the zs10pro? The zs7 is too big and very unpleasant to use.
post-15059455
Post #45,728 of 50,599
LaughMoreDaily
Canada
Canada
es4 were made doing the old process, they have re designed / engineered all the buds since. ZS10 Pro are amazing - i can't put them down.
Whats the "old process"? ES4 are amazing!
post-15059567
Post #45,729 of 50,599
PhonoPhi
Ontario, Canada
Ontario, Canada
post-15059642
Post #45,730 of 50,599
courierdriver
Canada
Canada
jcally cable for ZSN is wired for QDC (inverse of KZ polarity). not a sound issue, because both sides are inverted: not out of phase. so any other QDC terminated cable will serve as well as jcally cable
Hey hakuzen, I just received my TFZ No.3 and it also has those same Para C type connection ports as the KZ ZS10 PRO. I have another JCally 2.5 balanced 8 core cable on the way for it, but I want to start listening to the TFZ now, so I want to use the JCally balanced cable I already have on my 10 Pro. Do you know if I need to do any reversing of sides or anything on the TFZ, or do I just plug left to left and right to right, like I have done on my KZ'S when using the JCally cable? The TFZ No.3 came only with a 3.5 and I'm not a big fan of that flat cable that came stock with it. Any words of advice or suggestions?
post-15059671
Post #45,731 of 50,599
courierdriver
Canada
Canada
Well then, the Smabat ST-10 was made for you :) https://www.aliexpress.com/item/32993154088.html
Do you own these? If so, how would you describe the sound characteristics? I've got them in my cart on Aliexpress, but I would like more impressions before I decide if I wanna pull the plug on them. Also, how is the comfort? Can they be worn comfortably for an extended period of time? Thanks, MB!
post-15059679
Post #45,732 of 50,599
billbishere
Columbus, Ohio
Columbus, Ohio
Website
www.billbphotography.com
That is a neat looking headphone. From the 15" driver to the enclosure design! a little pricey
Reactions: courierdriver
post-15059890
Post #45,733 of 50,599
assassin10000
CA
CA
post-15059905
Post #45,734 of 50,599
Mlaihk
Hong Kong
Hong Kong
Just received the ZS10 pro and AS16 .Testing the ZS10pro at the moment. Gotta say the stock ear tips are crap. The sound is distance and very soft. But once I put on some TP45, boy they sound amazing! Vocal quality was excellent for thw price. Can't compare with my Andromeda S in clarity and soundstage but these makes excellent everyday earphones with my phone!
post-15060000
Post #45,735 of 50,599
hakuzen
plug them normally. if polarity is inverted (it means inverted position of pins in each side) you'll notice nothing, while the 2 plugs are plugged in same position. it will work as well as if polarity was ok.
Users Who Are Viewing This Thread (Users: 8, Guests: 29)
