post-15003529
Post #45,151 of 50,605
Slater
Cincinnati, Ohio USA
Is there a kz with better/stronger bass than the zs7? Ignoring everything else.
ZS4, ZS3E, ZS1 v1 are pretty much the most basshead stuff KZ makes.
Remember that tips and seal make a huge difference to bass. Most KZs are bassy, but if you don’t have a deep or tight enough seal they won’t be powerful enough.
post-15003533
Post #45,152 of 50,605
mbwilson111
Reactions: HungryPanda
post-15003539
Post #45,153 of 50,605
Zune
UK
UK
does anyone know how often KZ release a new model? I’m wondering how good a ZS11 Pro would sound :)
post-15003543
Post #45,154 of 50,605
Slater
Reactions: Rhino73
post-15003547
Post #45,155 of 50,605
RikudouGoku
Sweden
Sweden
Website
docs.google.com
Thanks, I use newbee foam tips so the Seal should be good
post-15003622
Post #45,157 of 50,605
Slater
Cool, thanks Slater. I'm guessing the 10 Pro hasn't been out long.
About 2-3 months.
And there’s no guarantee of that 18 month thing. That’s just been my observation based on their historical model release schedule.
There’s also exceptions. It depends on many things, including how well a model sells, other competing models, their product direction, costs, target market, etc.
For example, there is no ED10. It’s just the same ED9 they’ve been selling for years. The ED9 did get a new driver a while ago, but KZ never said anything, and it is still sold as the ED9, and it was a lot longer than 18 months from the original release.
So bottom line is don’t hold your breath or get your hopes up that by somehow by Christmas there’s gonna be a magical ZS11 Pro. It’s not like Apple or Toyota, where there’s an assurance of a a yearly release. KZ does whatever KZ wants, how they want, when they want.
post-15003632
Post #45,158 of 50,605
LaughMoreDaily
Canada
Canada
My ZS6 v2 seem to be working normally again... not sure what happened with them yesterday. They sound good but I am not a huge fan. ZS7 is very different but better...
post-15003774
Post #45,159 of 50,605
gourab1995
India
India
Actually, you could have just poked through the existing vent with a sewing needle. It would have been more accurate. The reason is these vents have a while filter adhered from the inside (like micropore tape).
You can actually see this on any transparent-bodied IEM like the KZ ZSR, ZST, ZSN, ZS10 Pro, CCA C10, etc.
Anyways, that filter restricts the air flow, effectively making the vent hole about 50% ‘smaller’. So if you poke through the white filter, you will in effect make the vent hole ‘bigger’, without actually enlarging the hole.
A very small hole is all that’s needed. For example, I make most nozzle vent holes 0.2 or 0.4mm, which makes a noticeable difference in the bass. Judging from the photo you posted, I estimate the hole you made is about 1.5mm (based on the hole’s size in comparison to an individual wire in the KZ upgrade cable).
I’m glad you liked the result of the mod; that’s all that really matters.
I cringe at the thought of all the aluminum shavings that might have fallen down inside that hole, because the dynamic driver is directly below. The metal shavings and chips will bouncing around on the fragile surface of the dynamic driver’s diaphragm. Whether or not you’ll be able to hear that remains to be seen.
When I drill the vent holes, I am able to extract all shavings and chips as I go, ensuring none end up inside. It’s taken me many tries to perfect my technique though.
Haha, ofcourse. Like you mention this might be cringe inducing. I only did this because I was already in state willing to sell them off for cheaper.
But I will keep your advice in mind next time I try something like this. If its any assurance, the shavings actually came outward. I was twisting the scissors in a way that thin metal strands were popping out. It was because I was using the sharp side on a slight angle to do it.
But now that I've done this. I'm not planning on selling again. Although I could have done a better job by making the hole like you mention.
After doing this I don't get that feeling that the bass is going to eat me alive on certain tracks and is less congested. Giving the treble more room to shine. Overall a good deal to me.
post-15003853
Post #45,160 of 50,605
pbui44
Member of the Trade: Like-New Ears
Yeah, foam tips seal in the bass, but you have to replace them a lot. I remember during CanJam RMAF 2014 a lady at the Comply booth helped me out in finding ear tips for my repaired JVC FX700 and they worked great at sealing the bass, but got smelly from my ear wax. I tried rubbing medical-grade hand sanitzer foam and the Complys literally disintegrated bit-by-bit down to the nozzle grip nubs.
Yeah, so the latest ear tip craze for me is the KZ starline flip-tip-mod by @Slater and it is even easier to clean, so I can hear clean bass even longer! :)
post-15004159
Post #45,161 of 50,605
KopaneDePooj
Studio Two, Abbey Rd
OK, new question :)
What's the warmest single dynamic front vented IEM? I'm not really into hybrids or BA. I just like a natural musical sound with a bit of punch / fun / non-fatiguing / full-bodied low mids, Similar to SoundMagic E10 or Shure SE215.
It can be anything else under 50$, not strictly KZ. And I promise I'll end my off-topic here. Remember, it has to have a front vent hole.
post-15004182
Post #45,163 of 50,605
Aparker2005
Usa
Usa
Should be interesting but I just got perfectly content with my zs10 pro and as16. Guess I'll see how the reviews go. Ugh
post-15004187
Post #45,164 of 50,605
PhonoPhi
Ontario, Canada
Ontario, Canada
post-15004198
Post #45,165 of 50,605
archdawg
This moment
This moment
i'm past the shiny new stage with the zs7 and would opine they're probably the best kz yet--i slightly prefer them to the zs10 pro. they don't play in the same league as the moondrop kp or toneking 9tail, but the difference is less than the price would suggest.
I guess that's why I haven't purchased anything in that 100-200€ price range for a while. I've said it before but with many good recordings my older, grey ZS6 are perceptually transparent to me most of the time. In those moments there's nothing left to be desired and I couldn't care less if there are technically better IEMs out there. Anyhow, I'm looking forward to auditioning some TOTL IEMs on the mainland in a couple weeks from now, but either I find something that literally blows me a-way right on the spot or my money goes elsewhere and I enjoy my chi-fis and xy cans for another while.
As to the ZS7 ... I love them to bits but ...
... I've had some issues with driver flex on the left earpiece and used a piece of pretty stiff #32 gauge (0,202mm) kanthal wire to open up both front vents in order to keep things balanced. I listened to a trusty test track directly before and after this little operation but couldn't make out any sonic differences; the sub-bass still kicks like a mule but now that driver flex is history.
Edit: like @Slater has mentioned: the 10mm DD sits directly behind that vent hole so in order not to mess up the membrane I used some needle pliers to hold that piece of wire so that only about 3,5mm would stick out - enough to do the trick.
Users Who Are Viewing This Thread (Users: 3, Guests: 26)
