May 15, 2019 at 2:53 PM Post #44,057 of 63,802
May 15, 2019 at 3:00 PM Post #44,058 of 63,802
Demo'ed the ZS10 Pro today. It is a great all rounder. Tight, punchy bass from the DD with realistic timber. Mids and treble has plenty of details with no fatigue or sibilance issues. Also good build quality and fits very well. Vocals can sound tinny or grainy at times, but that is just nitpicking, just crazy good value for the price.
May 15, 2019 at 3:03 PM Post #44,059 of 63,802
May 15, 2019 at 3:43 PM Post #44,061 of 63,802
How can I tell which one I have? I do not have the original box. I do use the dull filter..
If you remove the filter, you shine a flashlight and look inside. There’s a difference in the number of holes in the driver (which you can see through the metal mesh).
The biofiber driver has 7 small holes (6 around the edges and 1 in the center), and the titanium driver just has 1 center hole and no holes around the outside.
May 15, 2019 at 3:45 PM Post #44,062 of 63,802
Speaking of oldie-Goldies. Those HD9 ... worth getting? And recon the 2.25$ ones on AliX are authentic?
What about those bamboo ones?
:wink:
I have not ordered anything new in 24h !
HD9? Are you meaning the ED9's? If so absolutely but as far as the Bamboo ED7's you might take a pass on those (I think the Panda chews on his):grin:, they don't sound bad and for sure no where near a Best Buy $9.99 Skull Candy:smirk:
May 15, 2019 at 3:51 PM Post #44,063 of 63,802
I’ll verify when I get home, but from memory the biofiber driver has 5 small holes and the titanium driver has 1 big one.
That's ok. I don't want to remove the filter and maybe not be able to put it back.
May 15, 2019 at 3:55 PM Post #44,064 of 63,802
I do not see an ED7 in his list so if he had one he has eaten it by now.
May 15, 2019 at 4:05 PM Post #44,065 of 63,802
May 15, 2019 at 4:57 PM Post #44,066 of 63,802
By filter I’m talking about the shiny and dull changeable ones that screw onto the IEM body. Not to be confused with the nozzle ‘filters’ we usually are talking about (ie the stainless steel mesh screen).
May 15, 2019 at 5:35 PM Post #44,067 of 63,802
Oh ok thanks...I was thinking about the screen..probably,because you are often removing those for various reasons. :)
May 15, 2019 at 5:36 PM Post #44,068 of 63,802
May 15, 2019 at 9:02 PM Post #44,070 of 63,802
No, HD9 :wink:. Those guys
I miss the good old days, when all KZs cost less than $10. I remember how shocking it was when they hit $15. It was like whaaaa?
Now they’re pumping out >$100 models like it’s no big thang
