Yeah.. i dont like his reviews much..Lol not enough power to drive 5 BA drivers? No BA drivers need that much power -.-
Hyped about AS06s though
That sounds like a CCA advertisement. So do you wish you didn't buy the ZSN or do they still hold a spot close to your heart? It sounds like the C10 is a step up from ZSN but not from ZS10/AS10?The C10 sound different from the 3 you mentioned above, plus is a level up from the ZSN and will definitely bring you a mature and more premium sound signature.
Are you trollin'? As far as I know all KZ's cables are 0.75I need to know if the original zs3 takes a 0.75mm Cable or 0.78mm cable as there are two options to choose from for the Bluetooth cable on AliExpress. I think I remember it being 0.75 but I just want to confirm before buying.
So you definitely think C10 is the #1 now...??The C10 sound different from the 3 you mentioned above, plus is a level up from the ZSN and will definitely bring you a mature and more premium sound signature.
I Love Millie Bobby Brown and Stranger Things!So.. TechManZ preferred AS06s over AS10s..
MEE Audio M6 pro 2nd generation, if you like the sound, that it is actually not exactly laid backIt's been 2 years since I last looked at a new IEM. I just ordered myself a KSN & AS06. And just like 2 year ago, when I first got myself KZ-ATE, I am expecting good things again this time!
Anything else from KZ for less than US$50 that I should check out? My knowledge of KZ range after late 2016 is a total blank. Slight V-shaped sound preferred.
Thanks.
PS: And a big hello to those I chatted with back in the day!
Yeahh.. same hereI Love Millie Bobby Brown and Stranger Things!
Great gif!
0.75mm. As far as I know all KZ earphones with detachable cables have this standard for their connection. Although for a time when the ZS5 and ZS6 first came out there were some SPC upgrade cables being sold as KZ-compatible that had 0.78 mm pins. I bought 2 of those for my ZS5 v1 and red ZS6. It's been said the extra .03 mm will stretch the pin sockets and make them loose, but I cannot comment on this since so far I haven't had the need or reason to take them off. Well, that creeping green Fungus amungus on the ZS6 cable may be a cause for replacement, one of these days.I need to know if the original zs3 takes a 0.75mm Cable or 0.78mm cable as there are two options to choose from for the Bluetooth cable on AliExpress.
Thanks
A bigger hello from a new member!It's been 2 years since I last looked at a new IEM. I just ordered myself a KSN & AS06. And just like 2 year ago, when I first got myself KZ-ATE, I am expecting good things again this time!
Thanks.
Yes, been lurking for past week or so. Seems like ZSN is very well liked. And AS06 was more of a hopeful punt for me.Hmm...you've already a ZSN and AS06 on the way. I don't know about slight V-shaped sound but add to those 2 the ZS6 with round foam tips and I dare say you're covered for 2017 and 2018.
