The KZ ZSN sounded so good with the Kann that I simply could not believe my ears
However I found later my regular IEM the KZ ZS5 a bit more matured than the ZSN, but for EUR 15 the ZSN is an unbelievably good product.
Yep, JDS built this one with my box I sent them This particular was purposely built to drive my AKG-702's, dual 9 Volt's and it will drive anything I own John did a bang up job on this baby, can hardly turn the dial for efficient iem's but with all that power it's dead quite
What's with this "Weight: 10g+/-3g" everywhere? I mean, in the case of this item it turns out you get 30% more/less of your product! That wouldn't fly in grocery stores and markets! Outrageous!
Just in case they decide to change the chip at the last minute? Plus the weight of the pasted paper strips..?
KZ bluetooth module upgrade
https://www.aliexpress.com/store/pr...Wireless-Wire-for-KZ/4069015_32957037572.html
why they didn’t do BT 5.0 on this product
Pick a good pair of KZ's and try Ophélie Gaillard's Bach Cello Suites
GOOD LUCK TRYING TO LOCATE THIS 2000 RECORDING.
NEWER (2010)
No 1
No.6
Also, I highly recommend Gaillard's 2005 Vivaldi Cello works as well.
https://www.amazon.com/Pulcinella-S...llo+sonata&dpPl=1&dpID=5188VCICMnL&ref=plSrch
All recordings are great on the ZS5(v1) & ZS6.......not necessarily in that order.
