- Thread starter bhazard
Dobrescu George
Reviewer: AudiophileHeaven
Just to redeem from my off-topic last post, here's the rarity I'm driving today:
KZ IE80 with large foam tips, Tingo (too-cheap-to-be-really-)silver cable and Hidizs Sonata HD Usb-c dac.
The source is taking the picture.
Yes, it's a real newspaper there.
How many of you have the ie80?
I have the Ie80, also What, KZ makes Ie80 ripoffs?
Mellowship
KZ people tend to call it "tribute by imitation"I have the Ie80, also What, KZ makes Ie80 ripoffs?
mbwilson111
- Oct 13, 2016
Stop talking about that..it gets threads closed and brands banned.
Anyway that is an old discontinued item.
hakuzen
- Feb 9, 2016
i saw the wire of that 4 cores cable yesterday somewhere (probably by acrolink, but i'm not sure), but didn't know about the cable. the look of the wire is gorgeous.Papri is same as acrolink. There was even acrolink paper along with mine.
It sure looks nice but like I already said, rather stiff-sided not ultra soft like IT01 cable and impedance could be tad better imo.
Why?
Solder points only at ends and braided nicely (not heat-twisted like KZ). Connectors look ok too. Don`t know about impedance though. Hopefully hakuzen will chime in.
I don`t need it atm but when I need another mmcx, it will be the next.
Even around 35$ NiceHCK mmcx "silver plated" cable, which feels and looks really HQ one, has started to turn slightly green after about 2 years (with little usage and safe caring).
Don`t want another "silver" plated cable anymore.
i also saw 8 cores version of that wire.
0.08mm*19 is equivalent to 0.095mm2(section) / 0.35mm (diameter) / 27AWG. in the case of 4 cores, 1 core per signal, 27AWG is around 240mΩ roughly (1.2m cable, including about 15mΩ of plugs and solders, if they are decent).
in the case of 8 cores, 2 cores per signal: 0.19mm2 / 0.49mm / 24AWG. roughly a 130mΩ cable.
hakuzen
- Feb 9, 2016
Mybutthurts
Something is seriously wrong with Gearbest... a couple days ago, they had three colors for the ZSN and now they have four!
https://www.gearbest.com/earphones/pp_009268056629.html
A couple days ago, "Tyrian Purple" (I ordered), Medium Turquoise and Black.
Now they've also added, "Viola Purple".
What?
Is KZ adding new colors for this model?
It would appear that viola version is the original purple ZSN with silver back and cable
Tyrian one being new. Black back.
Also seen on twitter there's a Bluetooth adapter being released with ZSN type connections
LaughMoreDaily
Where is your source link?
Are you freaking kidding me?!!?! I already ordered the Black Back Black ZSN and now you're saying because it wasn't listed on their website I didn't order the Silver/Purple ZSN but a Black back/Purple?
I'm staying away from Gearbest from now on. I could have easily boughten it on Aliexpress by looking at a photo and these "clowns" only have 'text. I'm not impressed. I don't want a black/purple... ARGH! At least it better be the same cable as the silver/purple, if it's not... Gearbest is out for me, unless they have super-super cheap deals with actual photos of all products on sale.
LaughMoreDaily
Mybutthurts says the Viola Purple is the original Silver Back/Purple ZSN with the copper cable. They also said the Turian Purple ZSN on Gearbest's website has a Black back but didn't mention the cable type it had, original/dark or copper/clear.Viola Purple, right up @mbwilson111 alley's. that said, no indication of it on any official KZ channels
I hope they are wrong and the Viola Purple is the actual one with the Black back and Purple body.
CoiL
Member of the Trade: Wood Audio Accessories & Modifications
Thank You a lot! Will buy that cable for sure (2x4core and braid it together)!
LaughMoreDaily
If anyone cares - DD Audio seems to have the best photos of the ZSN that I have found on Ali. I apologize if they are a banned seller, because I didn't know.
https://www.aliexpress.com/item/KZ-...with-Metal-Resin-Housing-and/32949460599.html
Dobrescu George
If anyone cares - DD Audio seems to have the best photos of the ZSN that I have found on Ali. I apologize if they are a banned seller, because I don't know if they are.
They are not banned, and yes, they have some of the best photos, as well as some of the best service out there! It is a go-to seller for Chi-fi items at this moment
CoiL
I wonder if ZST faceplate will fit for ZSN? I will try it. Would be nice to have total-purple-seethrough IEM for my wife ;P
LaughMoreDaily
I wonder if that'll change the acoustics? And start a fight in the marriage, "I freaking hate you a-hole! This thing sounds like a badly manufactured fake ZST!"I wonder if ZST faceplate will fit for ZSN? I will try it. Would be nice to have total-purple-seethrough IEM for my wife ;P
