post-14287035
Post #33,106 of 49,453
Vestat
Milano - Italy
Milano - Italy
i see them on aliexpress for 1.2$ without shipping for 3 pairs(L M S) which i think is pretty high
come on man.. it's one buck! even if you find half priced, it's still half dollar less. is it really worth thinking about?
post-14287038
Post #33,107 of 49,453
Slater
Cincinnati, Ohio USA
can someone send a link to kz whirlwind tips deal
The Tennmak version is 3xs better. The KZ ones fall apart too easily.
post-14287050
Post #33,108 of 49,453
mbwilson111
We got a good deal on those Tennmak ones when you posted the link. I can't find the link now. Do you have it handy? We asked for them to all be medium and all in black... they did that. Black is really a grey though.
post-14287182
Post #33,110 of 49,453
mbwilson111
Reactions: Slater
post-14287264
Post #33,112 of 49,453
neo_styles
Los Angeles, CA
Los Angeles, CA
post-14287282
Post #33,113 of 49,453
mbwilson111
post-14287291
Post #33,114 of 49,453
neo_styles
Los Angeles, CA
Los Angeles, CA
You can order just the iems without a cable.
Are you referring to the hotfi or KZ? Either way, if that's the case, it's a really smart move.
post-14287299
Post #33,115 of 49,453
mbwilson111
The hotfi. I have no idea if that will be the case with the KZ... it should be.. like you said, it would be a smart move.
BTW, I am not suggesting that anyone run out and buy the hotfi on impulse. I love mine but it is a lot of money. My husband got it for me as a surprise gift because he knows I like purple :) I have the purple one. This is the cable I am using:
https://www.aliexpress.com/item/OKCSC-Earphone-Upgrade-Cable-5N-4-shares-MMCX-jack-Wire-Single-Crystal-Plated-Copper-for-Shure/32830043484.html
post-14287305
Post #33,116 of 49,453
neo_styles
Los Angeles, CA
Los Angeles, CA
If you see them more favorably than the KZ, staying under $100 isn't necessarily a bad thing.
I'll also attach the MMCX cable I got to replace both my Shure SE215 and Monoprice M300 cables. Super lightweight, but L and R aren't marked (simple fix: I just used a L/R test track *shrug*).
https://www.ebay.com/itm/KZ-MMCX-Cable-3-5MM-Upgraded-Silver-Plated-Earphone-Upgrade-Cable-For-Shure-LZ/142580163514?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
post-14287314
Post #33,117 of 49,453
mbwilson111
Yes, there are many choices for MMCX cables. I am guessing that KZ will continue the 2 pin system. I know many people think it is more robust.
Actually in the photo that was posted it is a 2 pin cable.
Reactions: neo_styles
post-14287330
Post #33,118 of 49,453
scottySK
Australia
Australia
Just wanted to confirm that the silver cable provided by KZ does NOT fit the ZSA. The 2 pin socket on this particular iem is the same as any other KZ offering, however the issue lies in the rectangle recession space that surrounds the socket. It is much thinner on the ZSA and so other KZ cables that have a thicker plastic border around the 2 pins cannot fit. I am thinking of sanding that plastic border down on the silver cable so it can be used on the ZSA, despite making it a looser fit on my other iems (this is my second KZ silver cable so bo real loss there).
I can post pictures later if anyone needs them
Edit: spelling
Reactions: rayliam80 and rfsux
post-14287389
Post #33,119 of 49,453
Slater
post-14287399
Post #33,120 of 49,453
Slater
Edit: spelling
Which version doesn't fit? KZ makes 2 - the ZST style, which is much chunkier, and the ZS3 style, which is extremely thin and slender. KZ sells all of their silver/upgrade cables in both plug versions.
There are many KZ (and TRN, etc) IEMs where the ZST style doesn't fit, but the thinner ZS3 fits perfectly fine.
Users Who Are Viewing This Thread (Users: 4, Guests: 12)
