  1. B9Scrambler
    Spitfits for me are very situational. They either work amazingly, or not at all. I find they're generally best with shallow fit earphones and those with a tricky fit (for me that is), like the ADV S2000, ZS10, FLC8s, EarNiNE EN1J and EN2J.
    SciOC likes this.
  2. DocHoliday
    The real question is..........drumroll please
    ......how do they differ from the ZSR (same exact drivers)?
    groucho69 and HungryPanda like this.
  3. HungryPanda
    Grrr they're hot property..... stolen from my very hands earlier
  4. nkramer
    anybody know a good place to get the 2 pin sockets (female, in iem)? about the only place i've been able to find is aliexpress.
  5. Dickymint
    Spinfits, I have several packs of them they came with some IEM's I bought, no matter what I try, I cannot get them to work, I just do not get on with them! In fact, there are very few silicone seals that I do get on with, they just don't seal in my ears. But saying that, I got a set of fluffy silicones free with a cable once and they are brilliant, have not been able to find them since though! Foamie's all the way!
    HungryPanda and SciOC like this.
  6. BadReligionPunk
    Yup. Tip rolling is completly personal preference. Everybody has differant physical makeup. Our ears are all different as well as our ear canals. Finding the right tip can make a huge differance.
    I just personally hate taking the time switching and trying differant tips. I just wanna plug and play.
    mbwilson111, HungryPanda and SciOC like this.
  7. SciOC
    I pretty much go starlines, new bee foamies then if I'm not satisfied with either I'll start truly rolling.
    I agree it's generally a pain and I tend to have best results with with the new bees and starlines. The only pair I can think where I don't use those are my ety er4p which I used the triple flange, and then the audeeze isine20's which I use the included medium groovy tips. Both those are odd ducks though.
    In general I think I must have large, shallow ear canals.
    IMO spinfits seem to be made for those with deep ear canals..... For me the Starlines go just as deep. Never tried spiral dots, but come on, they're not that different.
    Overall, tip rolling for me is a non-issue, if I get a good seal, any changes in sound signature are tiny.
    B9Scrambler likes this.
  8. willjie90
    Guys, I am giving away this free code. For whoever in need of new DAP or DAC. Not sure where to post so I will just post this here. You have around 30 hours left.
  9. HerrXRDS
    For me Spinfits work best. I'm using 145 and 155 with my KZ headphones, fit, comfort and sound is better than foams. Also on the IT01 most tips would change the sound when opening my mouth, Spinfits work great due to the rotating head. Different tips for different ears.
    SciOC likes this.
  10. HungryPanda
    I got the same offer today
  11. ChaoticKinesis
    I thought this way for a long time because I can definitely agree that at ~$15 for 3 pairs you may not like they're overpriced. But the truth is I haven't tried another tip that's quite like them. I have very wide ear canals and most large tips don't seal for me. The Spiral Dot large is probably the widest I've tried. Also, similar to the the Starlines, they are at their widest in the middle and not the bottom, like most eartips, providing a good seal without requiring a very deep insertion. They're also made of a tougher silicone, again like the Starlines, so they don't deform when inserted the way some of those paper-thin silicones do (I'm looking at you Xiaomi). Honestly, I'd happily use Starlines on all my earphones but not all of them like such a long tip. That's where the Spiral Dots come in.
    I've also seen several measurements with Spiral Dots where they actually smooth out frequency responses in ways that other tips do not. I'm not sure if I buy into the marketing of their special grooves and texture having any meaningful effect, but my ears tend to agree. They do not emphasize mids in the same way as most other wide bore tips, such as Whirlwinds.
    SciOC likes this.
  12. kailashrs
    After some extensive listening, I've decided nothing sounds amiss enough for me to suspect a miswired driver lol... I guess I was just being overly paranoid... Only quirks I have with this thing are the recessed vocals and the peak in the vocals that tends to get harsh... Still, I wish I'd gone for the TinAudio T2 which would've saved me all this paranoia lol..
    Bartig likes this.
  13. kailashrs
    So anyway, is there a phase test for miswired individual drivers?
  14. Makahl
    Multi drivers are harder to detect since you'll still hear the drivers which are properly wired. Individual tests you would need to take them apart which isn't an easy task or worth the risk. If they sound right using this test: https://www.audiocheck.net/audiotests_polaritycheck.php I'd not even bother, otherwise, the paranoia will make you don't appreciate it.
  15. kailashrs
    Yeah, my zs10 passed those tests but I'm afraid the paranoia and my ocd are getting the better of me xD, especially considering how prevalent these quality control issues are... But they sound perfectly fine... I'm just scared I'll miss out on better sound cause of miswired drivers...
