  1. WalterTorino
    It's hard to say will it be a good purchase or not. But you have to notice that there is gonna be a graphene DD (which promises a good, deep bass, better than in the zs10) and a crossover for only two drivers per side. I predict that the es4 will be just about a good, balanced sound with nice bass and soft but pretty detailed treble.
    As for me - $15-$18 is a good price to try it :wink:
    I'm waiting for the ed15 and the next stop will be the es4, for sure :)
    HungryPanda likes this.
  2. bsoplinger
    Size is 41x68x88mm which by back of the envelope is 1.5x2.5x3.25 inches. The typical $1 semi-rigid case is about 3.25in square. So no by my calculations. Unless you're talking the small single dynamic driver older KZ models like the EDx HSx ones and those would probably fit 2 without too much trouble.
    alex5908 likes this.
  3. alex5908
    Thanks. Do you know the ones I can put two earphones into one box?
    Does the one you mentioned fit for one KZ ZS6?
  4. DocHoliday
  5. bsoplinger
    I purchased this style for the ZS6 and others which have a rather large body because it feels like I'm squeezing them into the typical $1 round or square case.
    https://www.gearbest.com/headphone-accessories/pp_1307865.html?wid=1433363
    https://www.aliexpress.com/item/Mal...Box-Hard-Carrying-Pouch-Case/32598672367.html
    For a larger and would fit 2 pair case
    https://www.aliexpress.com/item/Ova...Ear-Earphone-Pouches-Storage/32734440071.html
    https://www.aliexpress.com/item/201...ortable-Storage-Bag-Box-free/32789937464.html
    The last link is to the Pizen store. I purchased some IEM and the case was big enough to sleep 4:ksc75smile: The particular product has the little ads to other products in their store showing a number of different size and style cases
  6. Aparker2005
    Well done kz, well done. Trying the blue ES4! I think the only other one I'll look forward to is the rumored 6 driver coming soon. I should have more than enough between these eventual 5.
  7. Superluc
    Where you have found that info ?
  8. Saoshyant
    Those cases tend to feel a bit on the small side overall.
  9. maxxevv
    If both of these IEMs do not have memory wires. Even then, it will be a tight fit.
    In fact, for IEMs with memory wires, a single one is already a tight fit. I bought an identical non-KZ branded one some months ago. Didn't find it practical for daily use as it was very limited in storage space and no separate pocket to store tips / sanitizing wipes / Bluetooth module etc.
    The squarish zippered ones work much better in my experience.
  10. snip3r77
    Buy it man. It’s so damn good
  11. snip3r77
    Take one for the team. Thanks
  12. WalterTorino
    Ali
    Superluc likes this.
  13. mbwilson111
  14. SomeEntityThing
  15. Zlivan
