oyobass
Wait, what??Yep sorry Zs6 versions - both have a Zs10 equivalent - just wrong pin size.
The ZS10 uses a different pin size? What size will they be using, if not the usual 0.75 mm?
By the way, at least in the past, the cables with straight ends are universal KZ fit, the anged-ended ones need modification to fit the ZS6, and other KZ IEMs that came with straight end cables. (All except the very early detachable cables, which reportedly had 0.78 mm pins).
