post-14081249
Post #28,771 of 50,631
NeonHD
Waterloo, ON, Canada
I'm pretty sure this has already been covered here, but wow I just found out about KZ's newest 10 models:
Honestly so excited when they release, I wonder how they all sound, and if it's a step above their current offerings.
Reactions: charlescc2
post-14081579
Post #28,773 of 50,631
Kevang
Somewhere else
Somewhere else
Has anyone managed to remove the tacky cursive writing from the ZSR's housing? I've tried both 91% isopropyl alcohol and nail polish remover but to no avail.
If there's one thing that's really bugging me about KZ's newest releases, it's the weird scribbles they plaster on otherwise pretty designs.
post-14081603
Post #28,774 of 50,631
bsoplinger
Cohoes, NY USA
Cohoes, NY USA
I went so far as to use the set of sanding / polishing sponges I have (1200 to 9600 grit) to see if I could remove the writing on the ZSR and it didn't work. I'm guessing that the writing is either embedded in the shell meaning inside because the shells may be made from multiple layers of whatever material they use or on the inside of the shell, although I don't think that's the case.
post-14081612
Post #28,775 of 50,631
fluteloop
Formerly known as Drumkrunk
Australia
Australia
I do not argue about it, it seems to be logical, but on a couple of russian music web-pages I saw information that balanced connection can cause a bass loose. Maybe it's true if it made not properly?
Balanced is for massive long cable runs, live pa's, studio's etc, i believe it was to combat latency and having wierd echo sounds. I could be wrong, i wonder how much difference it has on these baby cables.
Another thing that comes to mind is with those setups they can use ime alignment snd balanced alorithm to hone the sound, there's also more activity going on in the hardware, the clocks and data on the line, not something i would have thought audiophiles would be foaming about.
Reactions: WalterTorino
post-14081782
Post #28,777 of 50,631
Strat Rider
State of insanity that is California
Definitely appreciate the compliments from everyone.
Indeed, lipless nozzles are infuriating. I think we should be more vocal about it here or via KZ's new "qq" email thingy. I think it started with ED7 (maybe earlier, I forget) but it's purely poor design choice.
I use 3.5mm - 4.0mm eartip collars on the nozzles. My whirlwind tips slide past the the mesh like they've got somewhere to go, somewhere to be. I thought about using Teflon tape. It doesn't help that the nozzles are like telephone poles either. Folks with small ears might experience discomfort, but it depends on how small the aperture of their ear is. I'll have to check the specs for the nozzle width and insert that info into the review.
Recently I decided to place a black rubber o-ring over the ZSR nozzle to space the whirlwind tips out further.
instead of flush or near flush, the mesh is now recessed about 1mm.
I found that the fit and sq was improved.
post-14081784
Post #28,778 of 50,631
NeonHD
I hope that the YZ49 uses the exact same drivers as the ED9, just with an extra BA, because the ED9 has the best V-shaped sound I've ever heard.
post-14081787
Post #28,779 of 50,631
Strat Rider
I received two pairs of EDR2 in their classic dark cardboard box last week (gearbest). They sound identical and like the pair from mid 2017. Looking at the outdated appearing packaging including tips from before the "starline" generation, I speculate these EDR2 are all old stock.
Will submit two of them for measurements tonight (nylon vs. metal mesh).
i am currently listening to my edr2. Being my first non-hybrid KZ, I think I have been way behind. I like the shape, and weight a lot
post-14081793
Post #28,780 of 50,631
hakuzen
guys I need a cheap good portable dac/amp for my phone .... right now I think of fiio q1 first generation because its cheap... is it any good? .. can anyone think give me some advice what to get?
if you only need a simple and very portable dac/amp, i've tried smsl idea (= sabaj d2) and like it very much. it gets a bit hot and some people find buzz when using some phones (easily fixable though), but the clean (very low noise and distortion) and transparent sound, and low output impedance, compensate any small cons.
you can find detailed measurements here (and workarounds in comments): https://archimago.blogspot.com.es/2017/05/measurements-smsl-idea-usb-dac.html
check it to see if power is enough for your needs.
post-14081846
Post #28,781 of 50,631
bsoplinger
Cohoes, NY USA
Cohoes, NY USA
Just a bit of warning. A year ago there were hints of upcoming models from KZ and some never saw the light of day. I'm suggesting a wait and see approach to all things new from KZ
post-14081995
Post #28,782 of 50,631
CoiL
Member of the Trade: Wood Audio Accessories & Modifications
Estonia
Estonia
You could try denaturated spirit, make paper "wet" with it and wrap in food-plastic for a while. Furniture restorators use this method to remove laquer and stain from wood.
post-14082154
Post #28,783 of 50,631
bsoplinger
Cohoes, NY USA
Cohoes, NY USA
I've done similarly. Since the small size ear tips are always way too small for me I use them to make my spacers. I turn the tip inside out and cut off the part that goes over the nozzle. I then cut that in halves or thirds depending on how much spacing I think I need. Put it on the nozzle first and then the actual ear tip I want to use.
post-14082368
Post #28,784 of 50,631
Slater
Cincinnati, Ohio USA
How long did you let it sit on for?
post-14082369
Post #28,785 of 50,631
Strat Rider
I forgot about your OP on this subject. Kudos go to you.
Same as you, I have many unused silicone tips.
I'm going to use that. (I just happened upon O-Rings at work)
Users Who Are Viewing This Thread (Users: 4, Guests: 17)
