  1. CoiL
    Great post and keep up updating! :wink:
    Btw, I just bought that silver-transparent-white 2-pin with black rings jack cable You measured lowest impedance. Hopefully will get same good one.
    Will measure mine when I get it and post results. NiceHCK one with white rings really isn`t good when it comes to numbers (too high & uneven impedance), maybe will try to make it into custom (wooden plugs&bits) and resolder, maybe helps.
    hakuzen likes this.
  2. DocHoliday
    I suspected that they might be a slight annoyance, but I've no clue how to hide them under the spoiler heading. A brief "how to" and I'm good to go.
    BTW, anyone can chime in on how to do this.
    Also, good to know about the current ATR. I have two fresh pairs on the checklist and look forward to hearing them. It's one of the best all-around inexpensive IEMs IMHO.
    What are the differences that are immediately noticeable between the ATE(v) and ATR(ii)?
  3. MrSlim
    Has anyone found any cheap/good 2.5mm balanced cables with 2 pin connectors for KZ IEMS? I bought one of their 3.5 MM silver "upgrade" cables , and could re-terminate with a 2.5 MM TRRS, but I'd like to confirm if all 4 wires go all the way to the connector. Given that it's pretty cheap to start with it's no big loss, but it would be nice if someone has already gone down that path..
  4. CoiL
    I have removed nylon grills from nozzles on my ATE 5th gen... so, I removed them also from ATR to compare and used exactly same wide-bore smallest tips, both without mic, same song looping few mins before change ( Lifesigns - Cardington - Different , 16/44 FLAC, iBasso DX5X HO with HW&FW mods ), with Y-splitter, changing IEMs fast as possible (with song @ pause).
    These are most noticeable differences I could detect on 1 song basis:
    * ATE sub-bass/bass is slightly more present
    * ATR soundstage depth layering/positioning is slightly closer to headroom center point
    * ATR has maybe slightly better soundstage width but this maybe due to previous notice
    overall, differences are very small and when not concentrating on details, one may not tell the difference.
    But with good source gear and great mastered song - ATR is probably more "neutral" sounding and refined.
    Personally I think I still prefer ATE due to seemingly slightly larger soundstage and slightly more distant presentation/imaging/layering.
    Need more burn-in time as ATE is well behind 200h and ATR just about 5h playtime.
    Let me remind You that ATE 5th gen nozzle inner diameter went larger slightly and to me seems has exactly same physical build as ATR.
    Tomorrow will open both up and see if drivers are same looking or different as previously (ATE = red shell with tiny "tube" in front of diaphragm, ATR = blue shell without tiny "tube" and same hole size in front of diaphragm).
    DocHoliday and hakuzen like this.
  5. SomeTechNoob
    like this
    [sp oiler]like this[/spo iler]
    without the extra spaces of course
    mbwilson111 likes this.
  6. Podster
    Man I love little black Thongs:confused::rolling_eyes::scream:
    OK, back on track, look what just blew into town:yum: I've been reading everyone talking about this thing having the blue rubbery upgrade cable and I've got like three of them already! If this bass is all that on these with the tri-braid I'm ordering that better SP cable for them and the Red's/Black's may be taking a backseat:worried:
    Lord Rexter, HiFiChris and DocHoliday like this.
  7. ahmadfaizadnan
    Just received the ZSR. Sounds like a softer version of ZS6 with a wider soundstage. Of course, clarity-wise, ZS6 still a step further. Nevertheless, love the differences. Will let them burn in for couple days and update my impressions after.
    DocHoliday likes this.
  8. mrmoto050
    Give this a little listen
    Podster likes this.
  9. Willber
    To my ears that is what the CM5 sounds like, although it retains the clarity.
    djmakemynight likes this.
  10. ahmadfaizadnan
    did you mean uiisii CM5?
  11. Willber
    Sorry, yes.
  12. ahmadfaizadnan
    C2thew likes this.
  13. Willber
    Yes, there was a discussion about them a few days ago - some people found a code to get them for $8.99.
    I bought mine (blue) from Amazon.UK and have another (black, for spare) on the way.
  14. ahmadfaizadnan
    Cool! I'll leave my impression later.
  15. bsoplinger
    Not sure if you're a handy type person or not…
    I got this upgrade cable which was popular a bit back:
    https://www.aliexpress.com/item/Lat...e-0-75mm-2-Pin-2-PIN-Upgrade/32823059586.html
    Then this 2.5mm TRRS jack
    https://www.aliexpress.com/item/Sal...dio-Adapter-Converter-Solder/32663266504.html
    Had some of these from before but a bit of shrink wrap would do the trick if you don't:
    https://www.aliexpress.com/item/Sal...e-For-Sennheiser-Clear-Black/32718680699.html
    Took seconds to unscrew the 3.5mm jack on the cable noting which was the left and right positive line, lots longer to find my stupid multimeter and again seconds to figure out left and right negative. I spent the most time finding a diagram of the wiring for the 2.5mm balanced jack. A minute or two with the soldering iron and I was done.
    I went this route because the cheapest 2.5mm balanced cables I could find were $25 and didn't seem as nice to me as the $10 KZ cable.
    I'll even save you from having to hunt down the wiring
    For the AK 2.5mm wiring:
    [​IMG]
    For the HiFiMan 3.5mm wiring:
    [​IMG]
