mbwilson111
- Oct 13, 2016
Whats an "answering machine"??
Hey! I still have one!
Coupon code sale at GearBest. Quite unbelievable! It was the ZST version of the cable, so I will have to modify it to fit my ZS6.2.99? are you sure? It's unbelievable. So cheap. I like KZ ZS6 earphones. They are quite good for the price
Yeah. Seems like something like that while still small could have way better battery life than a tiny pack designed to be a fashionable bump in a regular cable.
Yeah. I've seen at least 5 people in a local audiophile fb group whom had bought new stocks of ZS3 (white box) that are complaining about driver failure. Their right earpiece are completely shot. No sound.
Yes. And they all got it from one seller. Seems like Gearbest has the same bad batch as well.Well that’s not a good sign at all.
So it’s always the right earpiece that’s died on all of them? How odd...
It depends on the use.Isn't the more the routing (more complex, more stages, more complicated) from the source to the speakers will causing more unwanted deviation toward the original sound??
Sorry as I'm an EE and believe in the more simple connection (prefer direct connection) from source to the end will have less deviation from the original as every single add on will contribute to artificial deviation from the source... just my 2 cents
But then you need to plug a 1.2m cable into that BLuetooth adapter and wind it around your neck or something?Yeah. Seems like something like that while still small could have way better battery life than a tiny pack designed to be a fashionable bump in a regular cable.
That cable is great, it never tangles and looks good. If the "memory" wire section becomes uncomfy, is very easy to remove with a exacto and pliers.Something special has happened, my ZS5 have finally arrived!
Ordered on 8 november for $12,99 + $1,17 shipping, arrived on 14 december.
Also received my bluetooth module on the same day that was ordered on 27 nov.
But since the pins are pretty hard to plug in, I can't see myself switching a lot. Got the nice grey-ish upgrade cable on it now. (https://www.aliexpress.com/item/New...32831364422.html?spm=a2g0s.9042311.0.0.eCPoyH)
Something from the 80's to early 90's.Whats an "answering machine"??
Anyone knows how to open up and fix KZ ZS3. I was using the brand new KZ ZS3 for about an hour and then suddenly the right earpiece becomes broken, I want to know how to fix it.
Same here!Anyone knows how to open up and fix KZ ZS3. I was using the brand new KZ ZS3 for about an hour and then suddenly the right earpiece becomes broken, I want to know how to fix it.
BE CAREFUL what you wish for!....you say his name three times, he pops up with tiny screwdrivers and needle nose tweezers and headphones start FLYING apart!@Slater 3 times and he will come to your house and make then better than ever.
When did you ordered your ZS3 from GB? I ordered an extra pair on October 4 but I sold it sealed last month, (Nov 10). I kinda regret it seeling now after these issues popping out.Same here!
i hope the second one i ordered wont be bad.
it seems that it will be bad too, same batch that gearbest has..
