Skyyyeman
Hello! I just received my KZ ZS6s, it took a while. I previously had a pair of ZS5s, but I think one of the drivers suddenly died on them, as mids started to be barely audible in the right monitor.
After listening to quite a few things with the ZS6s, I find them a mixed bag, mostly because each of the monitors sounds different. Voices are much crisper and louder in the left monitor when compared to the right one. As such, they are really annoying to listen to. They both fit snuggly in my ears, and I tried using various tips, the difference is still there no matter what I try. I feel cursed with bad luck when getting/using IEMs. My ROCK Zircons started having issues with the right monitor, the ZS5s suddenly went poof on me and now this.
What else can I try to do to find the issue?
It seems that you are describing essentially the same issue with both the ZS5 and ZS6 -- that the right side has less volume. That's highly unlikely and would imply that it's something else -- such as a source issue, or amp issue, or cable, or the way you have the cable plugged in, or...
