post-13803794
Post #23,956 of 50,614
Slater
Cincinnati, Ohio USA
My hope was to see them drop by $25 to $75 or so. I would be happy with anything below the $75 mark. I agree, below $50 and I'd start wondering if I was getting a fake. My short-list for 11.11 is the LZ-A4, the SW3, and the 1More Quad if any is available at a substantial savings.
You should be fine them.
Last year at 11.11 they were $70ish.
The problem is that Magaosi has MAP pricing. So once a few sellers dropped to $70 in the few days leading up to 11.11, other sellers complained and the whole plug got pulled for ALL sellers offering the K3. At the time you could only message sellers for secret unadvertised discounts. It caused quite the ruckus last year.
post-13803837
Post #23,957 of 50,614
briank996
post-13803854
Post #23,958 of 50,614
groucho69
7th circle of wife hell
Hmmm, I'd be shocked if you're going to see K3 at $50 unless they are one of the counterfeits. 1 member in the K3 thread bought some directly from the Magaosi CEO at an Asian electronics/audio show (I think it was 1clearhead but don't quote me on that) and pretty sure he paid COST (around $50 if I recall). The exact price is in the K3 thread if you want to search for it. But the bottom line is $50 is probably a pipe dream :0)
If they are selling for that, I'll pick up a spare set. Because I got bent over a barrel when I bought my original set for $130ish. So I won't feel so bad if I score a set for dirt cheap, because it will offset the 1st pair.
How many ears do you have?
post-13803895
Post #23,959 of 50,614
bsoplinger
Cohoes, NY USA
Cohoes, NY USA
*sigh* I just realized that I've ordered 3 pairs of ZS6. I had completely forgotten about ordering one from ali when I was ordering a bunch of foam ear tips. So when I got the notification that the gearbest order, from having used the discount code posted here for both a set of ZS5 and ZS6, was shipping I realized my mistake.
Maybe my cat needs a pair for when she watches TV when I'm gone
post-13803912
Post #23,960 of 50,614
Slater
post-13803915
Post #23,961 of 50,614
briank996
Would you be able to share a bit about how you got that cable to fit?
Thanks!
NM I figured it out, just cut the plastic shroud completely off.
post-13803919
Post #23,962 of 50,614
hakuzen
KZ 1week old foamies...
I dont use foamies much in the past..
didnt know there are gelfoamies.. fakefoamies with bones..
yes..n the real complys :)
U guys are EXPERTs..thanks!!
Was quite happy w spiral dots in the past... couldnt find a pair in my dusty candy cans.
measured ZS6 with these gel foamies.. they didn't have same effect than comply or regular foamies (silicon tube inside). they tamed the 8kHz peak, but not the 10-11kHz peak.
got tons of them, though, because they are useful to make your own DIY symbios: just cut the bottom part of the foam and insert it into a silicone tip, around the inner tube. you get better isolation if needed, without taming highs like regular foamies. used with spiral dots ("spisymbs"?), kz starline ("symbstars"?), and many others.
btw, ordered regular foams, together with some complys, for the zs6. found this place in ali which provides every size and color: https://www.aliexpress.com/item/20-...-earphones-enhanced-bass-Ear/32741636522.html
post-13804118
Post #23,963 of 50,614
EISENbricher
India
India
Hello guys, long time no see. Literally posting on head-fi after almost an year.
My trusted ED9 is facing wear and tear issues after using it for almost 1.5+ years. Now looking for a new KZ..
Which is a best choice below $20 currently? Will order ED9 again if it's still the best choice. Thx in advance : )
post-13804140
Post #23,965 of 50,614
young59
Can someone give the link to the gb thread I can't seem to find it.I didn't even knew about the "GBKZ" coupon would like to keep a track on coupons.
post-13804141
Post #23,966 of 50,614
Lord Rexter
Hyderabad, India
Hyderabad, India
Black and Green combo is AWESOME. I'll get Black ZS6 delivered to me this week or early next week, will do a Red and Black combo and post the pics here :o2smile:
post-13804143
Post #23,967 of 50,614
Lord Rexter
Hyderabad, India
Hyderabad, India
post-13804335
Post #23,968 of 50,614
eaglesgift
Chiang Mai, Thailand
i repeat: tried gray ones twice, one of them recently. both v1. i'm even doubting there is a v2, lol..
got zs6 already (btw, enjoying them with foams + a little eq). the only reason to seek for a v2 is to be able to measure them (fr, impedance..) and dissipate doubts for the team.
How recently did you get a v1 Grey from Gearbest? I only ask because I got a v2 a few weeks ago and I've seen a couple of other posts from people who also got v2 when ordering Grey no mic ZS5 from Gearbest.
post-13804395
Post #23,969 of 50,614
hakuzen
first one: ordered 7 sep , shipped 10 sep, received 26 sep.
second one: ord 22 sep, shipped 29 sep, received 10 oct.
both gray no mic, both v1, 2nd one defective, got a refund without having to return them.
i've been listening to v1 for some hours, using the new ofc gray cable and stock starline tips and an ultra low output impedance source (no coupling caps).
maybe these zs5 and the cable needed some more burn-in (?), they sound good with same songs, but not so good with others.
after some hours, had to change to zs6 (foams + some minor eq).
zs5 v1 is very finicky about sources, and i could say even about cables, due to its extreme low impedance (i was listening to them using lower resistance cables -the 6 cores with metallic straight jack- days ago, and got the impression of more songs sounding better; maybe my mood was responsible). btw, they need quiet more power than zs6 to reach same volume; i suspect they have lower sensitivity than zs6 (shall measure sensitivity soon), together with higher phase, more current needed.. batteries run out faster.
resuming, i've decided to follow your suggestions, not trying to get a v2, which would be probably worse than zs6 (no "crossover", harsher upper mids and highs, and more finicky overall -output impedance tricks won't be effective to tame the highs-). got a black zs6 instead, using the v1 refund plus the new coupon, to combine with my green ones (liked the look of @briank996 's :p).
if someone wants v2 to get measured, just send me them for a few days.. :wink:
post-13804623
Post #23,970 of 50,614
mono-type
If you're looking to tame the treble, go foams. I grabbed the Bees off Amazon and they're perfect (5-7mm).
Spinfits are awesome, but the regular spinfits don't really work for the ZS series because they're not a deep insertion IEM. The Blades, the cp240-m, do work a lot better, but I still prefer the foams for these.
Thanks for the heads-up regarding the SpinFits, as I'm really considering buying the CP-100M's. Good thing I've read your reply so I could save my money on something else! I don't see any CP-240M's yet locally; it looks like I could only get it through AliExpress etc. in the mean time. Regarding the "Bees", are you referring to the New Bee foam tips? Just want to make sure.
I recommend the mucho inexpensive T400 clones. I can't justify $20/set for comply's.
Same thing here regarding Comply tips. Let's see if I could find those T400 knockoffs locally. And also, how about KZ's own foam tips? I heard they get torn easily, based on what I've read on this thread.
Users Who Are Viewing This Thread (Users: 1, Guests: 26)
