post-13781040
Post #23,401 of 50,076
eaglesgift
Chiang Mai, Thailand
Yes, of course, it`s subjective. If You are very sensitive to highs (Your hearing is not damaged by loud music etc.) then v1 seems better. Just many have found v2 highs due to 2BAs in nozzle way too much.
I`m just generalizing overall opinions on v1 vs v2.
Can you tell me a couple of the songs/tunes you find better with the v1 than the v2 with regard to treble? I'd be interested to try and see if I can hear what you and others don't like about the v2. It is quite possible that I'm less treble sensitive due to listening to loud music as I played in a band in my earlier years and never used ear plugs. I also used to ride motorbikes long distances and I've read the decibel level of the wind when riding a bike is high enough to cause hearing loss with prolonged exposure (even when wearing a good quality helmet).
(I can hear the frequencies up to 18k on some tests I've tried online but I'm not sure how reliable they are)
post-13781135
Post #23,403 of 50,076
Paulo099
Can anyone give an impression or review of the KZ LP5? I've been looking for a bluetooth headphone under $50 and I can't find any review or impression in the internet.
post-13781306
Post #23,404 of 50,076
mrmoto050
Babylon
Babylon
Getting drivers out of ZS5v1/v2 or ZS6 is PITA!!! You need some serious patience and proper tools to do that - they are full of dirty sticky blue glue!
That's because so far as I've seen they have crappy insides that don't match the nice outside. Hence, why there is so much inconsistancies in the products. Seems like everyone has to mod this or mod that to get them to sound right. Poor workmanship, jmo
post-13781457
Post #23,405 of 50,076
Jay Magaling
Guys I'm using KZ starlines medium on both ZS3 and ZS5. When I push them all the way in, the ZS5 doesn't give that much resistance when I pull it out. Unlike the ZS3 that "burries" itself inside. So I think this might be the reason that I'm hearing a severe lack of bass from the ZS5. When listening to them A/B, the ZS5 sounds like it doesn't have any bass. The ZS5 just feels loose. I really feel that I don't get a proper seal. The bigger or smaller tips didnt help either. Should I go for foam with the ZS5? Trouble is I have to wait for 2-3 weeks for foams to arrive from ebay/AliExpress.
Sorry for the crappy description. I'm quite new to this.
post-13781460
Post #23,406 of 50,076
filltos
Iv'e got the Exclusive 5 and I was surprised by how much bass they have. I've used the shallow tips and the double flange tips that come with them and they sound great with both as far as bass is concerned. I think I'm getting a very close fit though, because I can hear some driver flex in the left side when inserting (my right ear canal just a little bigger I think). Did you try all the supplied tips?
How is the ZS5 compare with TFZ Exclusive 5? Is there audible improvement? TFZ are in my sight. Is it worth upgrade?
Reactions: Fox2twenty
post-13781477
Post #23,408 of 50,076
eaglesgift
Yes, absolutely. I still like the ZS5s but the TFZ Exclusive 5 is in a different class as far as I'm concerned. The main difference is in the texture, for want of a better word, of the mids...I'm not sure what kind of music you like but I used the first track off Dream Theater's 2013 album to test the two back to back and the crunchy sound of the guitar is far more present and detailed with the Exclusive 5s. Apart from that, I'd say they were a level up all round (detail, bass etcetera) but I'm not very good at describing sound quality. The easiest way I can sum up is to say that the TFZ Exclusive 5s cost me three times more than the ZS5s and I was really pleased I bought them when I first plugged them in. I was impressed, not disappointed. Only small negative I can think of is that the cables don't seem to fit very tightly into the sockets so I actually put a tiny dab of glue in mine. I don't think they'd actually drop out but I could see a couple of mm of the metal prongs after wearing them for a while and then taking them out, and it used to annoy me.
post-13781657
Post #23,409 of 50,076
mrmoto050
Babylon
Babylon
Those TFZ's look like RHA Clones with the exception of no filters.
post-13781660
Post #23,410 of 50,076
Slater
Cincinnati, Ohio USA
I don't think tip rolling to get improved sound is a negative thing, nor is it an indicator or poor workmanship and/or inconsistencies. Most of us tip and earpad roll just about everything we own at one point or another. Tip rolling is a valid and encouraged way to tweak the properties of an earphone for more individuality - helping with comfort, sound tuning, fitment issues, etc.
Do you actually own the ZS5, or is this opinion you have solely based on what you've read/heard/watched on youtube?
When you say "crappy insides", are you talking about the 'blue advesive', which is in reality silicone sealant used to actually IMPROVE IEMs by helping to dampen harmonics and reflected waves in multi-driver and especially BA-based IEMs? 90% of IEMs don't even have this additional feature, and KZ could have saved money by omitting it like most manufacturers.
It's a $20 IEM, mass produced in China. That's TWENTY DOLLARS - the same as a couple of Chipolte burritos, a few gallons of gasoline, or a few cups of Starbucks. For the price they are an incredible value. Go compare them to a pair of $20 earbuds from Best Buy, and see which one is "crappy".
Sure, there are a few QC issues here and there with KZ, but that's the case with every product no matter who the manufacturer is.
post-13781680
Post #23,411 of 50,076
mrmoto050
Babylon
Babylon
I own the KZS5, KZS6, ED9 , ATE and some others, I still think the "inside" workmanship is to coin a phrase "Crappy" and I do tip roll, that is usually a given with most IEM's. Sorry to ruffle your feathers.
post-13781690
Post #23,412 of 50,076
Slater
Don't worry, you didn't ruffle my feathers, and I wasn't assumimg anything other than the words that came out of your own post.
I was simply trying to understand where you were coming from that's all. You came across as bent out of shape over a $20 Chinese IEM not being the pinnacle of quality and worksmanship. And there seems to be quite a few armchair types that don't even own an IEM, yet have a strong opinion after watching a few biased YouTube videos.
We all hear things differently, and not every headphone is everyone's cup of tea. If you don't like the ZS5, move onto to something else that you do like - there's certainly plenty to pick from in the same price category. Life's too short to not enjoy your music on something you feel good about.
That's great that you tip roll, it it looks like you have a nice little collection of IEMs. I hope you find something that you like better, as we are all on that journey :)
Reactions: djmakemynight
post-13781714
Post #23,413 of 50,076
mrmoto050
Babylon
Babylon
Agree on the journey section and everyone has different preference depending on hearing, btw, I never said that I didn't like the ZS5, however I prefer the ZS6 over it. Also never watch youtube reviews, prefer to read (it takes more thought to write an article imo) I have a lot of audio equipment as I am sure you also. Cheers
Reactions: Slater
post-13781720
Post #23,414 of 50,076
groucho69
7th circle of wife hell
.I concur entirely except that I have no issue at all with cable fit. Nice and tight.
post-13781811
Post #23,415 of 50,076
TimeSnow
Dublin
Dublin
Used the ZS5 on two long bus journeys today... In fact am still sitting on a bus right now listening to them....for the money they're brilliant. Better than the other KZs I've heard... Haven't heard the ZS6s though...
Big fan of the brand, and particularly the price to performance ratio.
It's just an easy, cheap way to make your life nicer. What's not to like?
I can't wait for my LZ A4s, but for so so so so many people the ZS5s are all they'd ever need IMO.
Users Who Are Viewing This Thread (Users: 10, Guests: 14)
