Aug 8, 2017 at 8:22 AM Post #19,698 of 56,800
ryokun
Hi guys, I just ordered a ZS5+the upgraded silver cable from a local online shop and I'm expecting it to arrive tomorrow. I heard there's some QC issue? I'm new to the audio scene so I can't really differentiate a faulty unit and a good one. Can someone here help me so I can return the IEM if I get a bad one? Thanks!
Aug 8, 2017 at 9:23 AM Post #19,699 of 56,800
peskypesky
Texas
So that's two less than spectacular reviews of the ZSE already then :confused: - not the ZS5 killers as advertised. A new KZ earphone is always of interest though mine are still on route
Where's that hype train image?
Aug 8, 2017 at 9:36 AM Post #19,700 of 56,800
Vidal
Member of the Trade: Asian Provocative Ear
ZSE vs ZS5 - ZS5 are superior without question, ZSE lack the resolution and detail of the ZS5s.
The ZSE remind me of the ZS3 (they have more detail than ZS3) in that they're surprisingly good despite being a little warm and not having a huge amount of detail - a low res hero if you will.
Aug 8, 2017 at 9:37 AM Post #19,701 of 56,800
vector84
Colorado, USA
Most of the QC issues with the ZS5 have been phase (polarity) related and have been seen in both cables and the iems themselves (so check for phase issues with both cables).
Make sure you insert the cables the right way first.
Then phase is pretty easy to test and results should be relatively obvious when playing samples - audiocheck.net has some nice tests (a comprehensive headphone suite and a phase specific set) or you could google something like "headphone phase test" and try your luck, most should produce pretty obvious results when switching between in phase and out of phase samples.
If the results from the phase test are switched, you can swap the cable direction on one of the iems to fix the issue, though you'll want to modify the cable somehow if you plan to keep using them like that.
Some of the other QC issues that seem quite a bit rarer are going to be harder to pin down. Fit and tip selection can have a pretty huge impact on their sound, so you'll want to try playing around there for a bit. If nothing works and they just sound horrible no matter what you do (or just sometimes sound horrible?) then you might suspect one of the rarer QC issues.
And if anyone cares about my adventure, I heard back from Banggood and they told me they test everything before shipping (isn't that what they all say? but...) and given the measurements I provided (some uncalibrated side-by-side frequency response plots) that would appear to be caused by damage during shipping. So another set is on the way. Guess a 10 dB channel imbalance was pretty convincing :wink:
If they don't want the old ones back, maybe I should tear them apart and see if there's anything obviously strange going on inside... :thinking:
Aug 8, 2017 at 9:38 AM Post #19,702 of 56,800
BrunoC
Porto, Portugal
Thanks for the tip....but I'm no fan
That being said, I'm pretty underwhelmed with the ZS5s....glad I only paid $17 for them. I think they sound anemic when compared to my Rock Zircons and KZ ED9s.
Well, in my case, each time it put on the ZS5, it still impresses me with the overall clarity and balanced sound. Also the soundstage is very impressive. YMMV really, but for me the ZS5 is the best $20 chifi deal.
Aug 8, 2017 at 10:30 AM Post #19,704 of 56,800
Arkady Duntov
10th Circuit
You got the link and some PIC's? ....would like to see how they look.
https://www.amazon.com/Earphones-****-KZ-ZSE-headphones/dp/B0747S7BFV
[edit: I tried to post an image but it didn't seem to work. I guess I don't know what I'm doing.]
Aug 8, 2017 at 11:59 AM Post #19,705 of 56,800
mono-type
Where's that hype train image?.
This post from 13 pages ago. :laughing:
Simply drag the image you want to post on the field where you write your post. Something like this
On a side note, dunno if my ears are just getting used to the sound, but after a few hours of listening to it. I finally appreciate the sound signature the ZSE has. IMO, it's definitely have a warmer and darker sound than the ZS3 (especially when compared to a ZS3 with Slater mod + SPC cable + small stock silicone tips), and that says something, since ZS3 is considered a warm and dark IEM. The sound sig the ZSE had makes it a fun listen.
Aug 8, 2017 at 2:16 PM Post #19,707 of 56,800
khighly
Seattle, WA
Never go with the very first hype if you're on the edge about an IEM.
Aug 8, 2017 at 3:40 PM Post #19,709 of 56,800
Slater
Cincinnati, Ohio USA
Just found out that Etymotic foams go really well with the ZSE. Luckily I had quite a lot lying about.
How is the comfort with those? They don't appear overly ergonomic, so I'm just curious.
