acia
- Mar 4, 2016
Pure silver and copper cable.
Better instrument and bass. Vocal not tommuch difference.
I've removed the memory wire from my ZS5 and added some weights to the cable, it's much better as a result. I don't want to swap to another cable as 70% of the time I use the ZS5 straight from my iPhone and the mic cable has full iOS controls.
Interesting - I thought all of the memory wires had an actual metal wire inside.
So I was able to verify on a brand new pair of ZS3 that they indeed still have the acoustic foam inside the tube (ie early models = no foam, later models through current = foam).
Good call on the red filters - I swapped mine out for 4mm stainless screens as well.
Knowing the effect the red filters (vs stainless mesh) has on the highs, I wish KZ had instead put the filters on the ZST instead of the stainless mesh they used. The ZST would have been just the right amount of brightness then. Kind of ironic that they did the filters on the ZS3 when they benefit from the stainless mesh, and the ZST has the stainless mesh when they would benefit from the filters LOL
Only gone and ordered myself a blue pair of ZS5s in addition to my grey pair.
Why????
It was like a reflex reaction hitting buy when I saw they had dropped to £20, plus a store coupon taking another 1.92 off. I guess it's my subconscious telling me I like them!
Need to stay off aliexpress!!!
What did you use for weights?
Why????
Is that the stock cable? The pair I purchased off gearbest has a different cable in the picture.
ZS5 is now on sale in China
But it will change the details such as microphone
I can't tell you for now. Please understand
*Placeholder for my Official Review. I will keep editing this as I listen more. INITIAL THOUGHTS RIGHT NOW*
Overview: Eh...
Impedance:
ZS5: 4.15ohms
ZST: 8.25ohms
Comfort: The memory wire is bad. I am personally not a fan, but others have said they really like it. These IEM's are made out of plastic, but they do seem like they'll withstand a good amount of abuse before you need to spend another $25 on a pair. In the ear, they're hard to get and keep a seal. The stem seems way too big and not long enough which makes my ears hurt. You may have to play around with different ear tips to get a correct fit.
Isolation: Not great at all. Worse than the ZST's. Sitting on the light rail, I hear everything.
Sound: Get ready for disappointment here. These are 8+hr impressions. I don't see anything special here. Everything seems very neutral-ish and kind of muddy, but the top end of the highs scream with sibilance. ZST's have better sub bass and mid bass, and I could only recognize a slight difference in mids between them. Bass in the ZS5's seems very reserved and controlled. It's like an ATR with actual highs. There is a little more separation between highs/mids/lows in the ZS5's. So far, I think everyone has fallen for marketing, but I'll give it a few more days. They do sound better than the ZST's (especially in soundstage), but there isn't that big of a difference. Luckily KZ headphones are cheap and it isn't $200-$400 between different models.
Soundstage: Enormous. Much more than ZST and ATR. These are going to be very trippy when I enjoy some legal Cannabis later. I'm actually hearing placement of instruments and sounds in new places around my head.
Microphone & Controls: Microphone buttons are totally useless on my Pixel XL. Volume down drops the volume one, and then just pushes it back up. Pause/Play does basically the same exact thing. No use for this cable for me.
Verdict: Not the mind blowing experiencing everyone was hoping for. I think a lot of people fell to marketing. I don't hesitate to belive the post that says there are only two active drivers in them. They sound like a differently tuned ZST with even more missing mids. It's actually funny seeing people whine about the ZST sibilance, and then the same people say the ZS5 have controlled highs. Not the case.
Pictures:
Fine to have your own opinion, since hearing is so subjective. But there's no need to diss other's opinion just because they are different to yours, especially when there are alot of folks here with LOTS more reviewing experience than you.
