OZZERO
- Feb 4, 2017
I've had good luck with this seller on the tips:
https://www.aliexpress.com/item/3-Pairs-6pcs-L-M-S-In-Ear-Original-KZ-Tips-Earbuds-Earphone-Silicone-Eartips-Ear/32723329957.html
Ordered them multiple times with no issues. The most competitive price I have yet to find once you factor in shipping.
I am not sure which model they come on stock, but I have every single type of tip that KZ makes, and this one is just awesome. At the tip it becomes slightly pointed/cone shaped, which I think allows for a deeper insertion as well as being much more comfortable. The cone shape is similar to Spinfits.
You can see the shape here:
And instead of having a really wide flange like some of their tips, the hole at the end is very narrow (focusing the sound like a bass cannon at your eardrums). This is what made the ZS1 1st gen so powerful - it had a brass ring in the end of the flange that created a very narrow opening.
The other killer feature of the KZ Starline tips is the surface of the silicone isn't silky smooth like their other tips - it has a textured surface that makes it grip like nothing I have seen before. This is by far my favorite tip, and I like them better than Spinfits, Sony Hybrid, JVC Spin Dots, and KZ turbos.
You can kind of make out the textured finish in this photo:
And compare the flange opening of the Starlines to the KZ Turbos:
Thanks. How long does shipping take?
