Jan 8, 2017 at 7:53 AM Post #15,212 of 63,834
so it nothing to do with the ultra bass wordz,what a bummer i thought it will be super bassy iem when i first got it.:neutral_face::expressionless:
Sadly, it's a commonly used tactic which means nothing.  I just assume nothing if a headphone claims super bass, extreme bass, anything like that.
Jan 8, 2017 at 7:57 AM Post #15,213 of 63,834
Jan 8, 2017 at 8:13 AM Post #15,214 of 63,834
Jan 8, 2017 at 8:13 AM Post #15,215 of 63,834
ok that will be great suggestions i will the buy zs3 someday.ohh i heard its has same sound signature as kz atr right?.
You should also consider the ROCK Zircon if you want BIG bass.
https://www.aliexpress.com/store/product/Rock-Luxury-Zircon-Stereo-Headphones-Headset-3-5mm-in-Ear-Earphone-Earbuds-for-iphone-Samsung-with/2496012_32735944102.html?spm=2114.12010608.0.0.rdqgG2
+1
and another recommendation from me with BIG bass (but clear, detailed and thumpy bass) is YinJw IE800 wooden version but taking a fast look at AE, seems they are gone or discontinued? They are very good for EDM and such but also rumble Your socks off and make head banging with djent and such.
Jan 8, 2017 at 8:23 AM Post #15,216 of 63,834
And which is better zs3 or zst?
Since you said,you can afford 2 iems,get them both,keep the one you like most and sell/gift the other........both are liked by many here,so both of them worth a shot,,imo.
Yes zs3 is da bomb.......remember, fit may be tricky for some ears tho due to its shell design,just sayin.
Jan 8, 2017 at 8:39 AM Post #15,217 of 63,834
I have decided that I only take one. What is better to wear with a glasses, normal cable like zst oder The hard cable like zs3?
Jan 8, 2017 at 9:04 AM Post #15,220 of 63,834
And which Sound did you prefer?
While I like them both, the ZST to my ears is more detailed, where the ZS3 has more bass and is better suited to someone looking for a fun signature.  The ZST is by no means lacking bass, however.  If I had to pick, I'd personally continue using the ZST over the ZS3.
Jan 8, 2017 at 12:49 PM Post #15,222 of 63,834
This is a fun, VERY bassy little cheapo earphone; YHC S600. Cheap too.
https://www.aliexpress.com/item/Original-YHC-S600-bass-earphone-sports-headphones-dynamic-Headset-with-mic-for-iPhone-xiaomi-samsung-smartphones/32717330843.html?spm=2114.13010208.99999999.264.SvX0G3&aff_platform=aaf&cpt=1483897681186&sk=VnYZvQVf&aff_trace_key=48b01c62c6a24cf6803a864f07e8d4c4-1483897681186-01325-VnYZvQVf
Jan 8, 2017 at 8:36 PM Post #15,223 of 63,834
  Have any of you tried the silver cables for ZST/3? Did they make a difference? Considering just taking the plunge and getting ZST + Cable, instead of trying ZST, ZS3, and ATR.
In general, cables matter much less than the driver or the source. In the case of ZS3 and ZST, I found negligible difference between stock and silver cable, but immense difference between ZST and ZS3.
That said, the silver cable IS a bit more comfortable than the stock one, so get it for that if you want, or just to have an extra spare cable.  But the silver cable doesn't have the in-line mic as the stock one.
Jan 8, 2017 at 10:55 PM Post #15,225 of 63,834
What Iems is the ZST competing with for real? Xiaomi piston 2? Etymotic MC5? Soundmagic pl30? Just curious where these stand on isolation, particularly. But I am also curious about sound quality. Some stuff has turned me off. I like treble but not fatiguing treble, and I like bass to be as controlled and as tight as possible. No need to go too low. Mostly jazz music in my ears.
