Killer Bass from something PORTABLE
post-159953
Post #31 of 44
radrd
Found that torchiere lamps induce nicotine addiction in moths.
In fact it gives up, breaking up into vibrations before anything really meaty, if bass is what you're into.
Have you considered that your HD 280 Pros are probably defective? I have them and they sound great. The bass doesn't distort and I don't have any complaints about their sound.
If you don't like the comfort, then I can understand that. However, your description of how terrible the sound is makes me really think that yours are defective.
Of course, you have some strange appreciation for the V700DJs, so maybe your hearing is defective?
post-159965
Post #32 of 44
starch
Afroide, if you want a closed portable hp, check out the Sony D66 eggos. The bass may not be as prominent as you'd like, but they're small, detailed, and they're designed pretty well. The KSC-35s sound better at 1/4 of the price, but they're open and I personally have some tangling problems with them.
post-159980
Post #33 of 44
a1leyez0nm3
Originally posted by Magicthyse
The HD280 has an accurate and adequate bass response but it could never be called visceral. In fact it gives up, breaking up into vibrations before anything really meaty, if bass is what you're into.
I guess I should see what the fuss is about, like the 280's - and pick up a 750X soon - I've only tried the 7506 once and didn't really do them justice soundwise. Heck of a lot more comfortable than the 280's tho...
there must be something wrong with yours, mine can take all the bass in the world and not distort.... they hit a lot tighter then my 2 12" mtx's....
post-159994
Post #34 of 44
Magicthyse
Better to look good than to sound good!
Originally posted by Afroide
That's the one nice thing about the Koss KSC-35s. I can snag a pair of those, and can still try out those Sony earbuds just for the hell of it.
I'll let you know how it works out, but I suspect it'll be a while waiting for the iPod
Probably a good idea to have both in any case. Quiet area - Koss, public areas - EX70.
I rate the Koss units very highly - even the KSC-50/55 which some people rag on here - but they're too easily overpowered by background sound. And rather like Grados, when they're in that situation, they sound truly crap.
At least with the EX70's you are assured consistent mediocrity.
Having said that, I'm not sure how the iPod's amps will affect the EX70. Bearing in mind the standard earphones are 32ohm impedance, and they quote 30mw per channel, I can assume that they measure it as 30mw into 32 ohms. That's pretty damned powerful - since an EX70 has an impedance of 16 ohms. Not sure how they will behave on an iPod...
post-159996
Post #35 of 44
Magicthyse
I guess I must listen to 'crappier music' than you then, musn't I?
post-159997
Post #36 of 44
Magicthyse
I really did think about this. I doubted my hearing for a while, I can tell you. But I have decent gear besides the V700, on which my opinions seem to 'sync' with other people who talk sense - unlike some - and I do mean only some - of the HD280 cheerleaders. I also have perfect pitch.
There is also nothing wrong with my 280's - they are truly in rude health, and sound like other broken-in 280's.
And I do genuinely like the V700's for specific types of music, directly from a portable, on the move in high-noise areas.
Go figure.
post-160002
Post #37 of 44
Eagle_Driver
If you like your V700DJ's, that's fine. But for my wildly varying music tastes, I just don't care much for them - they sound okay for some types of music but horrible with others (oddly, I found them horrible with rock and "mainstream" pop myself, and mediocre at best with classical and jazz; in fact, the only type of music that I feel comfortable with out of the V700DJ's is rap - which happens to be one of my least favorite types of music).
post-160094
Post #38 of 44
r3cc0s
oh jeeze
u do realize that the more accurate the sound
the more real it is to what it is recorded
the flatter it is the better
excessive midbass is dumb!
post-160109
Post #39 of 44
jlo mein
In some place that's not Canada ....the right of the people to keep and bear arms shall not be infringed.
Ex70's do tend to get a little mid-bass boomy, but through some mods they can be made slightly better.
post-160149
Post #40 of 44
a1leyez0nm3
where did that come from??? Im just saying that yours may be defective! yeesh!
post-160671
Post #41 of 44
fredpb
King of the bass is the SONY V6 or mdr7506. Way way LOW but not boomy. If HD600's had this bass they would be the perfect phone.
post-160710
Post #42 of 44
rawhit
Afroide
if you dont mind sound leakage and prefer the grado sound then u should look into Grado 325s. I have SR-80s and SR-325s and I think that 325s bass is tighter, deeper and has more visceral impact.
they might not be the perfect match for a portable though
cheers
RawHit
post-160723
Post #43 of 44
a1leyez0nm3
the 280s bass is better, and it is said that the beyer 250-80 and 770 pros have even better bass.
i have used use the v6 and now use the 280 pro.
post-160751
Post #44 of 44
Khazim
I use the V6 with my iRiver ChromeX mp3/pcdp. I also use it on the computer. It works great for both. (I listen to mostly metal) I like deep bass, but not boomy, and the V6s do that well. These are my first pair of decent cans though. They're fine for me now, but I know once I get money I'll probably save up for something a bit better.
