@KHADAS I am going to order the RCA to XLR 0.2m. How can I add this to my Khadas Tone2 Pro that I already ordered so I will not get charged again for shipping?
Khadas Tone2 Pro: Mini Desktop DAC with built-in Headphone Amplifier
- Thread starter KHADAS
Bastianpp
- Aug 11, 2016
Meh.
This product have MQA, I will not buy a single MQA product .
Yep, sure thing! just contact our sales for instructions.@KHADAS I am going to order the RCA to XLR 0.2m. How can I add this to my Khadas Tone2 Pro that I already ordered so I will not get charged again for shipping?
Yes, you are missing something. But not with the Khadas Tone2 Pro. Based on specs, it can drive demanding cans. Consider: a typical 32 ohm headphone has 100db sensitivity at 1milliwatt. Now, a +3db increase in spl requires double the power. Meaning at 2milliwatts, you get 103db. At 4 milliwatts, you get 106db. At 8 milliwatts, you get 109db. At 16 milliwatts, you get 112 db. At 32 milliwatts, you get 115db. . . . If the amp can output 211 milliwatts at 32 ohms, then at 211 milliwatts you get 122.9 db.Very attractive product and I would definitely consider if I didn't have my current stack.
Im an amp noob but am I missing something? It says 3 stage amplification, can drive demanding cans but output power at 32ohms is 211mW/125mW meanwhile a magni (my current amp) puts out 2.4W at 32 ohms?
Even with a headphone with 300ohm impedance, where you get a max of 83milliwatts, you get 115.8db. This translates to 5 volts.
Now, you wouldn't want to listen on headphones at 115db.
Besides, you can connect the Tone2 Pro to your Magni if you think you need more power.
Dolores Dolomites
This looks almost too good to be true at this price point, and a perfect semi-portable solution for me (lappie + DAC/Amp with the ability to upsample my FLAC library to DSD256).
And it namely _looks_ very good, which gets some extra points!
I'm right on the brink of biting the bullet...
D'you guys with some wider expertise think it's going to _sound_ too bright (as in piercing bright) with some fairly fizzy electrostatic IEMs like I've read before?
Also, will it be able to drive some 300Ω cans decently?
Thank you in advance, and have a Merry Christmas!
Baten
- Sep 13, 2012
-bright, perhaps, hard to tell in advance
-300ohm cans should be driven fairly well but 150ohm like the HD58x even better
Yeah. Looking forward to my 58X with this. IF it is bright, then the 58X will pair nicely.-bright, perhaps, hard to tell in advance
Dolores Dolomites
/me *facepalms* Geese... I don't see why you'd say that, Bastian friend, other than pointless fundamentalism.Meh.
Don't like MQA? Look away and don't use it.
Simple as that.
Impressive specs and the ability to upsample my library to DSD256 through HQPlayer will prolly do just fine for me.
Awaiting my black Tone2 Pro unit... (tap a-tee- tap, tap, tap) Can't wait to get my dirty hands on it ! =)
monsieurfromag3
I love how Khadas managed to unlock 768kHz PCM resolution and, more importantly, lower output impedance significantly (0.3 instead of 2.4 Ohm on BAL output!) mere days before launch.
Amazing, yes. It seems too that it now has optical in. I just can't understand how.I love how Khadas managed to unlock 768kHz PCM resolution and, more importantly, lower output impedance significantly (0.3 instead of 2.4 Ohm on BAL output!) mere days before launch.
captblaze
all that’s left is hearing what it is capable of. (Fingers crossed and waiting in anticipation)
Yeah. My THX 789 is waiting.all that’s left is hearing what it is capable of. (Fingers crossed and waiting in anticipation)
SenorChang8
The lower output impedance was the final straw (it’ll suit my IEMs) preordered.
@KHADAS is there an estimated price for the Bluetooth module?
Questions for @KHADAS
1. In the email update there is mention of optical in. Can this be confirmed?
2. If we use the bluetooth module in the I2S port, how will the Tone 2 Pro get power? From the other USB port?
Thanks!
Thanks!
Nope, the T2P(Tone2 Pro) only supports S/PDIF Coaxial IN, rather then Optical IN.1. In the email update there is mention of optical in. Can this be confirmed?
And to support S/PDIF Coaixal Out feature, you will need to:
1) Upgrade with dedicated firmware(without MQA support)
2) Use Balanced RCA to Stardard SE RCA cable
Yep, both USBC ports can power the T2P.2. If we use the bluetooth module in the I2S port, how will the Tone 2 Pro get power? From the other USB port?
