FullBright1
Here is a mini Review of the : Khadas Tone 2 Pro
So, what is it?
Its the TONE 2 PRO from Khadas.
What does it do?
Well, it does:
ESS ES9038Q2M Dac
It does 4 OPA1612 operational amplifiers
It does Hi Rez - Up to 32bit 384KHz sample rate, bit-perfect DSD512
MQA
Its does Balanced and SE
It does a great Volume Knob
It does it all in a nice metal housing.
-and MORE.
Its a very nice portable Dac/Amp made for the person who wants a KILLER Dac but does not need the product to be the size of a shoebox or weigh 9 kilos or 20 lbs.
Enter : Khadas Tone 2 Pro MQA Balanced Portable DAC HPA
How does it sound?
It sounds like Hi End gear, miniaturized.
I discovered this Dac/Amp on a UTBE review channel offered courtesy of my favorite Youtube reviewer.
This guy.
He states that its world class, and you dont need anything else, unless you have really hard to drive headphones, in which case, you can buy this one for all your other headphones.
So, based on his remarks, i found out he is correct. (Again).
Tonally, it reflects its High End Dac. As this Dac setup is designed for clinical clean transparent revelation, and that it does.
This is not warm fuzzy roundness, this is straight wire analytics.
The Khadas Tone Pro 2 come in different colors, they are shipped from China, and mine was delivered in ONE Day, from China.
I'll take that everytime i can get it, as im not one who enjoys waiting.
The faster my gear shows up, the happier i am.
So, the Tone Pro 2 sounds very good, its a quality piece, and its affordable and portable, and offers a really good Volume knob.
What's not to love?
Here are the specs and some photos.
The specs will tell you what you need to know regarding ins and outs and the rest.
The gear is brand new and it already has (15) 5-Star reviews already posted on the site in the last week, obo.. So, you should consider it, and maybe hurry.
Here is the page link. https://hifigo.com/products/khadas-tone2-pro?_pos=1&_sid=9dacaa5e9&_ss=r
Other additions to the Tone2 Pro include a 4.4mm balanced headphone jack in addition to the standard 3.5mm single-end jack. The Tone2 Pro's aluminum enclosure incorporates a hybrid digital/analog volume control knob, allowing you to rely entirely on analog signal attenuation for accurate sound reproduction. With not one, but two USB-C ports, you can connect a 5V linear power supply to the second USB-C port whilst having USB-C data on the first for excellent power-noise isolation. Finally we've added an industry-first balanced RCA line-out. These novel RCA ports have three signal-pins instead of two, yet retain the same size and form factor as regular RCA ports.
The latest addition to file format support is MQA decoding. The onboard XMOS XU216 processor enables bit-perfect, hardware-native, USB class II, asynchronous "unfolding" of MQA data for both web streaming and local high fidelity audio playback, enabling future-proof "original master quality" audio reproduction just as the artist intended, but at reasonable file sizes and streaming bandwidth requirements.
So, what is it?
What does it do?
Well, it does:
ESS ES9038Q2M Dac
MQA
-and MORE.
How does it sound?
This guy.
What's not to love?
- DAC + Headphone Amplifier - Tone2 Pro combines the ESS ES9038Q2M with x4 OPA1612 operational amplifiers that deliver superior audio quality.
- High Performance - Up to 32bit 384KHz sample rate, bit-perfect DSD512, and -118dB THD+N (line-out).
- Hardware MQA Decoding - XMOS XU216 processor for full MQA decoding, enabling next-gen "original master quality" web streaming and audio playback.
- Balanced RCA - Next-generation "balanced RCA line-out" with 3-pin output, sets a new interface standard for the Hi-Fi industry.
- Linear Power Supply - Tone2 Pro has a second USB-C (I2S) port that supports 5V linear power supplies for ultra-clean signal-to-noise ratios.
Description:
Tone2 Pro is our second-generation Tone Board from Khadas that incorporates a variety of user feedback from our first-gen product, the Tone1. ESS ES9038Q2M DAC has been paired with four powerful OPA1612 operational amplifiers and three buffer amplifiers. This 3-stage amplification pathway enables Tone2 Pro to drive a wide range of demanding audiophile-grade headphones with impedances of up to 150 ohms. The OPA1612 was selected because it provides superior audio quality and excellent distortion characteristics; THD + noise is below 0.00008% throughout the audio range (20Hz to 20kHz).Other additions to the Tone2 Pro include a 4.4mm balanced headphone jack in addition to the standard 3.5mm single-end jack. The Tone2 Pro's aluminum enclosure incorporates a hybrid digital/analog volume control knob, allowing you to rely entirely on analog signal attenuation for accurate sound reproduction. With not one, but two USB-C ports, you can connect a 5V linear power supply to the second USB-C port whilst having USB-C data on the first for excellent power-noise isolation. Finally we've added an industry-first balanced RCA line-out. These novel RCA ports have three signal-pins instead of two, yet retain the same size and form factor as regular RCA ports.
