Dear Community!
It is with great joy and anticipation that we announce the upcoming launch of our latest hi-fi audio product the ‘Tea’, an ultra-slim high-resolution headphone amplifier for smartphones. This portable amplifier features the high-performance ESS ES9281AC Pro DAC, as well as LDAC and aptX HD bluetooth audio via the Qualcomm QCC5125 chip.
Why Tea?
‘Tea’ was created to satisfy a high demand from our community for a “Portable Tone2 Pro”; many music streaming apps such as Spotify and Apple Music now have high-quality lossless music that can only be fully enjoyed when you connect a portable DAC such as the ‘Tea’ to your Android or iOS smartphone.
Pocket Friendly
'Tea' measures just 7.95mm at its thickest point, which means it can still comfortably slip into your pocket even when magnetically attached to your smartphone.
LDAC & apt-X HD
Android users can enjoy the freedom of wireless high-resolution digital output direct from a streaming app via aptX HD and LDAC from a Qualcomm QCC5125 bluetooth chip. Sample Rate: up to 24bit 96KHz
Magsafe Compatible
"Khadas Tea" magnetically attaches to your iPhone 12 or newer smartphone, or an Android phone equipped with a MagSafe compatible case. No more messy wires and dongles, just freedom of pure style.
ESS Technology
'Tea' ultra slim high-resolution headphone amplifier is powered by the high performance ESS ES9281AC Pro DAC, which delivers desktop-class audio. Sample Rate: up to 32-bit 384KHz @PCM, or DSD 256 (Native)
Analog Output
'Tea' brings back the analog audio jack to your smartphone with 3.5mm output, so you can use your favourite high-fidelity headphones to listen to lossless streaming audio directly from your streaming app. Supports up to 300 ohm impedances.
THD+N, 1KHz, 300Ω: 0.000355% (-109dB)
Max Output @300Ω: 20.8mW (2.5Vrms)
Max Output @32Ω: 165mW (2.3Vrms)
Lossless Audio
Did you ever wonder what "Lossless Audio" means when you open Apple Music or Tidal? These are high-fidelity audio tracks that can only be rendered at their original quality with an "external DAC-amplifier" such as "Khadas Tea" attached to your smartphone.
Inbuilt Battery
'Tea' incorporates a high-capacity 1160mAh lithium-polymer battery that provides up to 8 hours of continuous playback time, so you can enjoy your high-fidelity music throughout your entire day without draining your smartphoneʼs battery.
Bluetooth Calls
'Tea' includes two inbuilt microphones so you can receive and make calls without removing your headphones. Press the 'power' button to accept the call, and speak into the microphones located next to the USB-C port.
Bit-Perfect Audio
For the Audiophile who must always have a bit-perfect audio connection, a wired connection guarantees that you're always listening to the original data stream. 'Tea' includes two cables in the box for connecting to your iOS or Android device. Each cable measures 100mm in length (w/ plugs), cable diameter of 2.1mm. The USB-C to Lightning Converter is MFi Certified.
Available On Indiegogo
Creating 'Tea' for your listening pleasure is no easy feat. Show your support for our project by joining our Indiegogo Crowdfund. Your contribution will enable us to bring this breakthrough hi-res audio product to market.
Technical Specifications
Why Tea?
Pocket Friendly
LDAC & apt-X HD
Magsafe Compatible
ESS Technology
Analog Output
Lossless Audio
Inbuilt Battery
Bluetooth Calls
Bit-Perfect Audio
