iwik
- Jan 3, 2014
Hi All,
Has anyone built the above amp?. I did a few years ago and have just got back in to trying to setup
biasing following Kevin's procedure. There seems to be quite a large drift in output voltage at idle
measured between + and - Outputs. Both channels exhibit this variation. If you look at the meter over
a 5 min period this standing voltage varies from +10mv to say 900mv. Then will drift down again.
Hoping someone or Kevin may pop in for some advice would be appreciated.
The amp sounds ok, really nice in fact.
Thanks
Les
Thanks
Les
