Hi all,
Some last nice comments on the Odin mk2 on the french forum HCFR.
http://www.homecinema-fr.com/forum/...rton-fischer-audio-inside-t30059943-9015.html
Otherwise, I'm going to surprise you, I'm currently listening to a lot of the headphones Thror on pop / rock music, with the XI Audio Formula S amp in high gain position (low negative feedback), that give the most of tied, the most of natural and a better presence for voice, and with Kennerton's Custom cable giving more consistency and thickness and also more of natural for voice, although stressing less the upper treble than the cable Vectura C (upper treble are a bit lower (roll-off), although more natural, with Kennerton's Custom cable + Thror).
In particular, I listened last night to the voice of a French singer Alain Souchon; listen to this CD with amazing precision and a great tonal rightness.
I appreciate all the more this headphone that I do not listen too loud at night, in calm (note the sound volume SPL should not cover a snap of fingers) which allows me to appreciate the true value of the tone (note: tone which varies according to the sound volume SPL, but also, slightly following the centering of the pads on the ears).
Finally, no problem for wearing the headphones Thror, very comfortable, even several hours in a row.
Trick: wear the headband quite forward on the skull, halfway between the top of the skull and the top of the forehead, in particular if you listened with the head a little leaning back in your chair/sofa; comfort will only be better.
