KB EAR Audio impressions thread
post-15166374
Post #62 of 159
Nimweth
Sussex, England
Sussex, England
Nice. I really enjoyed the F1 so I too have a pair of the 06 on the way. Hoping they'll arrive tomorrow.
Yes, the F1 was good, I was lucky to get one with the Bellsing 32257 driver. You will enjoy the KB06, I'm sure.
post-15167053
Post #63 of 159
dcvanderbush
What has been the general experience of the "swivel" connectors on the Tri units vs the two pin plugs? I had some real cheap universal iem with the swivels and on broke off in the Shell shortly after I started using them. Any good or bad experience / advice on that front? That's really the only thing that I'm unsure about with the Tri items.
Edit: and the KB Hi7... That's tempting, except the connector...
post-15167364
Post #64 of 159
nraymond
New England
New England
I think by "swivel" you mean the standard known as MMCX, which has been around since the 1990s:
https://en.wikipedia.org/wiki/MMCX_connector
It's much more of a standard than the 2-pin connectors (0.75mm pitch, 0.78mm pitch, Paragraph A, Paragraph B, Paragraph C, QDC, recessed, raised, rectangular socket, keyed socket, rounded corner raised socket for cable with a shroud, etc.)
A proper MMCX connector is rated for a minimum cycle of 500 connects/disconnects. If you had an IEM fail before the 500 cycle count, it was defective and/or badly designed. High-end earphones (such as the Campfire Solaris, retail $1500) often use MMCX.
The TRI I4 is well built, solid metal body, MMCX connectors are solid, and I've had no trouble so far connecting/disconnecting cables a few times (not that I do it often with my earphones, once I settle on my preferred cable I tend to stick with it).
post-15167434
Post #65 of 159
Slater
Cincinnati, Ohio USA
I know the 'official' rating is usually 500, but my personal rule of thumb is <30 cycles with mmcx. Any more than that is literally a gamble.
It's not about being high quality or defective or poorly designed. A tight fitting mmcx jack, coupled with inserting or removing it a little crooked, or using Gorilla grip force or being stupid and using something like pliers will trash even the best quality mmcx.
Honestly, the only time I swap out an mmcx cable is if I got a new/different cable, or if the cable is bad (which is the point of having a removable cable).
Because I limit the insertion/removal cycles as much as humanly possible, I've only ever had 1 mmcx jack break in my life. That even includes mmcx implementations in IT, such as external Wifi antennas.
post-15167591
Post #66 of 159
HungryPanda
Kent, UK
Kent, UK
I always treat mmcx connections with kid gloves and even I have had a few disasters
post-15167738
Post #68 of 159
George Taylor
Upper Chichester PA
Upper Chichester PA
The 06 did arrive today, been bouncing around my music library with them since getting home from work. In short, they're lovely sounding. Especially for the price point.
Reactions: Nimweth
post-15167989
Post #69 of 159
baskingshark
Jabberwock Island
Jabberwock Island
Are 2 pin connectors rated better than MMCX for disconnecting/connecting shelf life?
I've seen some custom IEM shell makers charge more money to include a 2 pin connector than an MMCX one.
Though I've seen my friend's 2 pin connector break off inside the IEM shell part before.
post-15168104
Post #70 of 159
Slater91
Milan, Italy + London, UK
Website
www.soundphilereview.com
Usually, yes. And that's because 2-pin connectors have larger pins and no parts that click. They can break, just as anything else, but it's rarer.
post-15168162
Post #71 of 159
Slater
Agreed.
post-15168575
Post #72 of 159
Nimweth
Sussex, England
Sussex, England
That's right, and even better after a good burn in period!
post-15169806
Post #73 of 159
George Taylor
Upper Chichester PA
Upper Chichester PA
Quick mini review. They have good depth to them, especially compared to the F1. A bit more of a "fun" sound, I find the F1 to be pretty straight forward & neutral. These have a bit more bass emphasis. Not basshead level, but definitely there. Really need to break them in more before getting too into it. I like them more than A few of the other Chifi I own in the same price area, and more than some I have that are a bit more expensive.
Reactions: Nimweth
