You can googe translate on Tabao's customer feedbacks.
https://m.intl.taobao.com/detail/de...fgOTlKRw/BskwVSk6Xf4qfQDXk5aHifGDWcN5bXXq9+8=
Thanks, btw do you know what are the air bag at the tube section part for? And what tubes do they use?
Not sure, just hope the air bag can withstand the heats!Thanks, btw do you know what are the air bag at the tube section part for? And what tubes do they use?
Ok, its using American Raytheon subminiature tubes. I googled about airbag protection for vacuum triode, could not find any. Anyway if you smell something fishy while playing, you will knowI'm more worried that the plastic air bag would melt under the heat!
How does it compare to little bear B4? (What opamps are you using in B4?)the "airbag" my assumption is to reduce the "ZIIIINNNGGG" sound came from the American Raytheon subminiature tubes when there is shock, tho the "Ziing" sound still there but as much as the Little Bear BX series.
was using Muses02 - TAP1 wins in technicalities, power and detail.How does it compare to little bear B4? (What opamps are you using in B4?)
what sound does the Opamp intended to be ?Just pull the trigger on the amp without LPS on Aliexpress Summer Sales, will consider custom 230V LPS later. Also ordered Oracle ll opamps to roll in it as well .
So far have you rolled any opamps?
Dunno but can withstand heat.what sound does the Opamp intended to be ?
Price is both amp+ PSU?Ooh 1 last stock became available from the seller back at $280, just jumped on it. The other seller is selling at $390, so that is quite a big difference.
Opt for free shipping so this will be a long wait lol
