K81DJ Foam Mod Trouble -- Need Help
Aug 24, 2007 at 10:13 AM Thread Starter Post #1 of 6
m1k3-tets1
I pinched the the foam inserts out. Now one of the thin cloth disks that cover the driver grills is just a tiny bit not so strained as the other one. I must've pinched it thru the foam insert and it's no longer snug fit on one side (by the smallest margin). No severe folds, really. It just doesnt look as flat as the other one. I failed to fix it just by pulling the cloth and I dont want to take the plether pads off. Mayb it's paranoya, but still: can it effect SQ?
Aug 24, 2007 at 10:28 AM Post #3 of 6
Originally Posted by richierich /img/forum/go_quote.gif
Does it sound affected?
Thanks for quick feedback. Well, I don't hear any difference at all so far but I have not burned-in the cans yet. Mayb I poorly explained what has happened (I'm Russian). The cloth disk just looks not so flat and strained as the other one. That's all. Still I feel a bit uneasy. I'm a perfectionist.
Aug 24, 2007 at 6:26 PM Post #5 of 6
Yeah if the cloth isn't that flat I wouldn't worry about it too much. Just keep enjoying your new phones!
