JVC new top tier Wooden IEM : JVC HA FX 1100
Mar 19, 2017 at 2:31 PM Post #606 of 661
james444
OK, so, it's FW01 vs FX11/1200. I read that FW01's mid is a bit more forwarded, bass tighter, and the treble less peaky. The last part is why I loved the FX1100, they had superb treble. Can you point out in what ways FX1200 is still better than the new FW01 ? They also say the FW01 shows more details., do you agree ?
The most notable difference is bass, the FW01 are less boosted. If you liked the amount of bass you got from your FX1100, then stick with them
Mar 28, 2017 at 6:41 AM Post #611 of 661
malifact
I listened to the JVC range a while ago in Japan and I liked the v-shaped sound.  If I wanted that sound signature with more of a treble boost than bass (but still boosted) and good for female vocals, would the FX1100 or FX1200 be suitable?  Or would I be better off with another IEM from JVC?  Also, I’d prefer something that didn’t protrude too much from the ears if possible.  Thanks.
Mar 28, 2017 at 7:22 AM Post #612 of 661
Sotiris
FX1100 AND FX1200 ARE THE SAME
Mar 28, 2017 at 8:54 AM Post #613 of 661
WoodyLuvr
Friend of Blur Earphones
siam
Concur with Sotiris, the JVC HA-FX1100 and JVC HA-FX1200 are one in the same... just different markets.
The FX1100/1200s do protrude from the ear more than my FX750s did, considerably so... all the Woody IEMs protrude due to their design and the rather large wooden diaphragm sitting inside the IEM but the size is well worth it to gain the amazing imaging and timbre (which results in excellent female vocals by the way).
Edit:
I had all intentions to buy the the FX1100/1200s but ended up buying the FX750s instead at a fraction of the cost as they fitted extremely well and sounded much, much better to me in the imaging and timbre departments... I listen to a lot of ambient (classical and electronic); female vocals (opera/choir/new age/rock).
Mar 28, 2017 at 9:53 AM Post #614 of 661
malifact
Edit:
Thanks for the response.  How does the FX750 compare to the FX1100 and 1200 sound wise?  Are their sound signatures similar?
Mar 28, 2017 at 10:52 AM Post #615 of 661
WoodyLuvr
siam
Here is my review and few insights when I demoed the entire JVC Woody line back in 2015:
http://www.head-fi.org/t/708427/the-new-jvc-fx850-woodie-perfection-a-review/3000#post_11544448
http://www.head-fi.org/t/708427/the-new-jvc-fx850-woodie-perfection-a-review/2985#post_11543709
http://www.head-fi.org/t/708427/the-new-jvc-fx850-woodie-perfection-a-review/3000#post_11544714
http://www.head-fi.org/t/751798/jvc-ha-fx700-vs-750-vs-850-etc#post_11545915
