bobeau
- Jan 15, 2005
This is an easy fix if you're comfortable using a soldering iron, you could replace with something more robust or a right angle.
http://www.showmecables.com/category/3.5mm-Connector.aspx
I think it's durability as well. I've already replaced the cable on my TF10's due to a short in the 3.5mm plug after an amount of usage and just went with an inexpensive cable. I don't want to have to do this to the FXZ200's because of flimsy stress relief. For now I'm buying a short extension cable with an L shaped plug to take the stress.
