rgs9200m
- May 15, 2006
Thanks to you too. I will report back on the results. I looked in the Jriver forums and didn't find anything either. Best to you.
Does anyone use the equalizer in Jriver? I find myself using it to slightly reduce the highs ( -2.5 db at 6000 hz) on my Senn HD800s and a similar amount at higher frequencies on my Grado GS1000i.
I don't think I detect any distortion. Any comments? Thanks.
I have had digital files ripped from my K2HD discs play on JRiver with no problem at all. Just wondering if the issue is with the CD tray of the computer?
OK, I got an LG BE14 external usb3.0 cd-rom drive (a blu-ray thing) and now the K2 discs are read and ripped just fine. Thanks for the advice!
when i enable their volume leveling i must compensate by almost doubling the volume control on my amp for the same output. using itunes volume leveling i only need to up the volume about 10%. take it for what it is worth.
to me the biggest disadvantage of volume leveling especially in the jriver case (because it is so extreme) is that if i switch to watching a youtube video or answer a skype call or watch the news all the sudden my speakers and ears get blown out. always shocks the h out of me and i have to frantically scramble for a volume control to turn it down and back up again returning to my music.
it is just to much in jriver and they really need to include a volume leveling output volume slider on the effect so i can choose how conservative it is.
I know they switches from traditional volume leveling (Replay Gain) to a more modern standard (R128)
Maybe you audio simply needs to be reanalyzed for R128 because what you are describing is really excessive.
JRiver recommends to use Volume Leveling together with Adaptive Volume, wouldn't be surprised if enabling Adaptive Volume brings everything back to normal
can some one please list top 10 rated plugins for equalizer vst pluggins
