JOLIDA JD2A VACUUM TUBE HEADPHONE AMPLIFIER With JD10A ISOLATED POWER SUPPLY UNIT
Status
Not open for further replies.
Type
For Sale
Currency
USD
Price
180.00
post-7582354
Thread Starter
Post #1 of 6
audiowalker
USA
USA
AAMore equipment that I am clearing out. Purchased this set from a fellow Head-Fi member so I think I am the second owner. Units are in excellent condition and work great. These also come with the power umbilical cord and power cable. Also, included is a step down transformer in good shape. It has seen better days. No original boxes, though. My thinking is to box each one separately, including the tubes. Then place all into one box. I am not sure what the final weight will be so shipping costs will be at the end when everything is packaged and I know your zip. Shipping will be via UPS or FedEx, insured, with tracking number. Here are the specs from Cattylink.com:
FEATURES:
High-end vacuum tube headphone amplifier.
Isolated power supply unit
Alps volume control
Stunning dynamics with fantastic vacuum tube sound
Detachable power cord (IEC)
TECHNICAL:
JD2A TUBE HEADPHONE AMPLIFIER
FREQUENCY RESPONSE: 15Hz – 20KHz (+/- 1db)
INPUT SENSITIVITY: 700Mw
S/N RATIO: >80 db (NW)
TOTAL HARMONIC DISTORTION: <= 0.4% (1kHz, 100mW)
INPUT IMPEDANCE: 100 kohms
OUTPUT LOAD IMPEDANCE:    32ohms, 320ohms, 600ohms
DIMENSIONS: 250 x 122 x 100mm (W/D/H)
VACUUM TUBES: 12AX7 x 2 + 12AU7 x 2
JD10A POWER SUPPLY UNIT
INPUT VOLTAGE: 220V / 230V +/-10% / 50Hz
OUTPUT VOLTAGE: DC 300V, 50Ma; DC 12.6V, 1A
DIMENSIONS: 240 x 122 x 100mm (W/D/H)
VACUUM TUBES: 6Z4 x 2
POWER CONSUMPTION:  40W
PM for questions. If you would like more pics, just PM. Thanks for your interest. Cheers ~
post-7582666
Post #2 of 6
drapels
Can you tell me what kind of tubes are in the unit? Thanks.
post-7582679
Post #3 of 6
audiowalker
USA
USA
Hi there:
I knew I forgot something in the list. The tubes look like the original Chinese version that came with the amp. I never got around to changing them.
post-7642994
Post #4 of 6
Hifianddrumming
Any negotiation?
post-7717974
Post #6 of 6
twothemaste
i apparently cant send more than 2 pms a day but if you send me your email ill speak with you there
Status
