JISBOS question
Jan 18, 2016 at 5:34 PM Post #16 of 35
Well, even the pirated bds pay tribute to cavelli and his audio genius.
Jan 19, 2016 at 6:54 AM Post #17 of 35
Hey FA
Did you have to add heatsinks to the regulators on the amp once you installed the jisbos? I am thinking it will cause them to work harder once I install JISBOS .
Jan 19, 2016 at 11:29 AM Post #19 of 35
I will double check those. Its been a while since I have built this.
Jan 19, 2016 at 3:42 PM Post #20 of 35
Good advice. You should have plenty of voltage after the bridges to allow the regs to be 15V. That will give you more voltage swing through the JISBOS and at the same time, it means the regs will run cooler. IOW, you get a two-fer.
Jan 20, 2016 at 7:10 AM Post #21 of 35
Thanks for your input tomb.
Now I want to get some half way decent wire to wire these up.
Any suggestions?
Jan 20, 2016 at 11:01 AM Post #23 of 35
so, you don't believe wire will affect sound quality?
Jan 20, 2016 at 12:15 PM Post #25 of 35
True. This can open a big can of worms.
Jan 20, 2016 at 2:52 PM Post #28 of 35
Handmade sells Belden 8300XX by the foot.
https://www.hndme.com/productcart/pc/viewCategories.asp?idCategory=19
They also have pretty nice solid silver wire but you have to buy the insulation separate.
Jan 20, 2016 at 5:06 PM Post #29 of 35
Thanks Tomb and mister
The wire shop looks interesting and fairly cheap.
Jan 20, 2016 at 5:10 PM Post #30 of 35
I don't see navshipps. I see PTFE wire but none labeled navshipps
