goodvibes
- Dec 28, 2009
For what sounds good? Absolutely not.
For what is marketed as a 2.5k mastering tool? Well define what makes a proper mastering tool. Measurements are usually involved in that discussion.
For what is objectively flat frequency response? Yes.
The only less than perfect mechanism is us humans
I don't disagree with this but it implies something that measures perfect, should be. That is very much not the case and if there's something wrong that the measurements don't describe as is not uncommon, it's your ears that will tell you so. Measurements are good at measuring the parameter in question but is no more perfect at finding overall or complete goodness in a device. It's an interesting situation where some art in design and subjectivity in evaluation will always be in the mix.
What I'm saying is that measurements are good tools at finding things that could be improved but are not good for absolute goodness evaluations. It should measure VG and sound VG to be VG.
