vincentm66
- Jun 24, 2013
Hi Hipnick,
What sources / player do you use?
Cheers
Cheers
this puzzles me, coming from the 1p2 the Layla's have mid-range in spades...That's the main problem with these. And it's definitely not a fit issue (that would make the bass missing). Fortunately that's fixable (by digital means), but unacceptable for the price.
Hi Hipnick,
Cheers
What is the reference point for IEMs with a great mid-range?
Agreed re seal, sometimes I get it, others not at allOnly issue is the eartips. Difficult to achieve that perfect seal. Bass at 12 o'clock.
I identified two significant dips at around 2k and 4k. They are quite deep, but that varies from one amp to another. The whole area between 1.5 and 5k is affected (too many dips there TBH), with these two being the most obvious.
As shotgunshane says, that's not really a problem if you're not doing critical listening. You can enjoy these for years (if the cable doesn't break meanwhile) if all you need them for is listening to music. No problems for that kind of application if you're not looking for reference sound.
