JH Audio JH5pro thread
68 69 70 71 72 73 74 75 76 77
79 80 81 82
  1. AntonnyCH
    Hello, I don't know whether it's proper or not asking this question in this thread,
    I currently own a pair of JH5, and thinking of buying another pair of CIEM as an upgrade. Is there any CIEM that has the same sound signature like JH5 but with better quality?
  2. cj3209
    I'm told that the JH-13s are a pretty good upgrade.  I upgraded to the Angies-which sound fantastic.
    Although keep in mind that with a high-quality cable, the 5s sound pretty d*&m good.
    CJ
  3. Vitor Valeri
    I have a friend who has the JH5 and JH13 FP. He said the JH13 does not have the same signature as the JH5, the JH13 has the bass and mids more recessed than the JH5.
    I would choose to upgrade the Angies.
    PS: I recommend the same as the CJ regarding the cables: purchase best cables for JH5 that will sound great! I bought for my JH5 the Effect Audio Ares.
  4. Spyro
    JH16 is the logical upgrade to JH5.  I have owned both at the same time and JH5 is a poor man's JH16.  Same sound sig.
    JH13 is totally different.
    I did extensive comparision earlier in this thread if you are able to search my posts.  Other wise the questioner can PM me and I will oblige.
    proedros likes this.
  5. cj3209
    My apologies, I meant the JH-16 - that is what I heard was similar to the JH-5s.  Sorry about that.
    CJ
  6. AntonnyCH
    Thanks for the advice, Well, after reading your review on JH5 + Effect audio Ares, I'm now tempted to purchase upgrade cables and see if it's enough to satisfy me. :D
  7. dimensiid
  8. Gryphus0204
    Does anyone know how does the Fidue A83 compare with the JH5? I really want a custom, and im considering reshelling my Fidue... But its a hybrid and some companies dont do it.
    Would the JH5 be something better? Or similar standards with different sound signature
  9. JKT48
    if you reshell fidue A83 it will have different sound, because of different resonant chamber in IEM housing before and after reshelled
    Sent from my Nexus 4 using Tapatalk
  10. Gryphus0204
    in a good way? or bad way?
  11. JKT48
    it can be good or bad, depending on your previous sound preference from fidue A83.
    And reshell dynamic driver can be tricky, some company, like kumitate Lab, prefer to reshell Senn IE800 with its original housing, to not alter the sound of IE800 itself
  12. Gryphus0204
    Hmmmm so what would you recommendation be?
  13. JKT48
    if you still prefer A83 original sounsig, stay to it's universal fit, don't reshell/remold it.
  14. zaintachik
    Just got mine. Burning it in. Thought I had a bad fit but just discovered the twist method. The 1st time I pulled out i thought I pulled out my ear canal. Painful. Getting used to a ciem. First impressions are pretty good
  15. Spyro
    For the money, and the fact that it's a custom....it may be the best money you ever spent in audio, period.  Just a fantastic dual driver IEM.  It does it all.  The poor man's JH16.
79 80 81 82
