JH Audio JH5pro thread
post-7507325
Post #781 of 1,217
FlyBPR
Hi guys,
Would customs be ok for someone who is still in high school and therefore possibly still growing a little, or would I be better off with a universal?  Is there a certain age where the shape and size of your ears stop changing?
I've also seen customs for sale here, is there a place that you can get them remolded if you aren't the original purchaser?
Thanks
post-7507537
Post #782 of 1,217
Spyro
Freshman...probably not, you will grow more.  Senior...you are probably okay.
post-7507766
Post #783 of 1,217
Anaxilus
What if he's a 20 year old freshman?
post-7507773
Post #784 of 1,217
Spyro
Then I would assume he's done growing (???)
post-7544428
Post #785 of 1,217
Anaxilus
Started a new thread for those who would like to contribute their JHA experiences.  All opinions welcome.  I think it would be beneficial to both JHA and potential customers.  Might also help remove some clutter.
post-7544452
Post #786 of 1,217
Laney
In the end I decided to send mine back for a refit of the left monitor. The bass was slightly weaker and I had to adjust that phone every now and then to keep the seal. The audiologist I used offered free remolds so I decided to go ahead and get one, even if JH Audio weren't sure they would need one. Hopefully I'll have them back in two weeks or so from now; I'm already missing them even though I only had them for little over a week before sending them back.
post-7552668
Post #787 of 1,217
theglaze
Can anyone compare the passive isolation of these IEMs to ear plugs with a similar rating (~26dB)?
I ride a motorcycle with plugs rated at 32dB reduction, and my Sennheiser CX500s just don't offer anything close to that. I'm hoping a set of custom IEM will take the edge off my exhaust while enabling me to listen to music at significantly lower levels.
post-7552682
Post #788 of 1,217
Anaxilus
A full acrylic shell can't exceed -26dB or so.  You want something w/ vinyl tips like Westone or 1964 (optional) or a full silicone shell like ACS or Spiral Ear (preferred for max isolation).
The cheap solution would be some Etys w/ custom silicone tips from ACS.  The universal needs to have the tip molded around the housing to fit under your helmet and the Ety/ACS system is the only one I know that does that.
post-7553596
Post #789 of 1,217
Anaxilus
The problem w/ sleeves is they don't stop resonance and transmission from the housing and don't fill the ear as completely as a custom.  But yes, silicone seem to attenuate better by about -6 dB or more over acrylic typically.  Hollow acrylic, I know Earsonics is solid acrylic.  Not sure about that.
post-7556616
Post #790 of 1,217
DRahl
Maybe I should post this on the new appreciation thread Anaxilus started... but after months of waiting/deciding I finally ordered my set of JH5s.   They are set to arrive this Thursday and I'm extremely excited.  I've experienced great customer service throughout.  Approx 2 weeks from receiving the impressions and I'll have them.  Some extra time might've come from the artwork.   I've attached the mockup they did (free of charge) for my approval.  Can't wait! Will post pic of IEMs/initial impressions when I receive them.
post-7560227
Post #791 of 1,217
Bazirker
I've never wore a motorcycle helmet, but a colleague of mine rides with Ety ER6i's with Comply tips and it works well for him.
post-7561028
Post #792 of 1,217
Trinity
Yes, those do work with helmets from what I read, but the other Etys are all too long to be worn under a helmet.
Yes, you are correct. I wear a snug fitting Arai and there is no way that my ER4Ps or HF2s would fit under there. =8-0
post-7565929
Post #793 of 1,217
DRahl
JH5s rec'd!  Seem to have received next day UPS without paying extra for it. $$$
Sound is AWESOME, though I admit I am no professional.  Sometimes the bass seems somewhat lacking unless I push them against my head.  They fit in the ears well, but I'm wondering if they are a tad too small in the right ear (and thus the bass issues).  Should they be snug (as in tight fitting), or is the fact that they fit fully into my ear canal enough?
Perhaps I'm too used to the rubber suction feeling I got from my old Shure e3s rubber tips....
post-7565953
Post #794 of 1,217
rmappita
First, will be nice to know if you are wering it right. Like this video http://youtu.be/JQ59keE-GxM?t=1m23s
After you can clap your fingers to see if you have a good seal in both ears.
And you can use this Sensaphonics test :  http://www.sensaphonics.com/?page_id=833
Rodrigo
post-7570301
Post #795 of 1,217
DRahl
Tyvm for the replies!  And thank you for the audio seal test.  Unfortunately, in both ears the 500hz tone is considerably louder than the lower tone even when it seems like an ear has a decent seal.  Though it is interesting, when I play "heartless" by Kanye West on FLAC the bass seems pretty full (could be that is is overexaggerated in the song though).  I will try oto-ease and if no better luck, JH Audio said they'd be happy to refit.  I had my impressions done at a reputable audiologist in Tampa but perhaps, to your point, she simply didn't go deep enough.
Thanks!
Christopher
