JH Audio JH-3A
74 75 76 77 78 79 80 81 82 83
85 86 87 88 89 90 91 92 93 94
  1. Bina
    Swifttal: Nc8000 isnt talking about using standart headphones.
    NC8000: From information from jhaudio, I think that every Jh-3a is tunned to unique pair of jh13/16. So if you use it with different pair, you arent getting optimal sound. But this is just my guess
    Shanling Have any question about our players? Just PM me or send me email. Stay updated on Shanling at their sponsor page on Head-Fi.
  2. swifttal
    Sorry I misread... Yeah that's correct
    This was also addressed - the dsp is tuned for each individual earpiece. Now if youre thinking about buying one of each (13&16) for the jh3a, I think if you talked w/ Jerry he would talk you out of this as since the bass is adjustable you can "de-tune" the bass of the 16 to essentially give you a 13's sound signature.
    If after this consideration, say if you already have the 13 and still want to get those retrofitted as well as getting the 16 with your 3a purchase... Then the only workaround I see happening is with Jerry giving you the "DSP maps" for both drivers and you would have to load each map yourself on the 3a prior to switching between the 2 as only 1 "map" can be loaded at a time.
    -I'm pretty sure he'd talk you out of that one as well though
  3. nc8000 Contributor
    Thanks for the replys, that was exactly what I was thinking as well but didn't know. I will not be getting one in forseable future as finances are thight but at least I'm well happy with a standard JH13 with TWag and Protector.
  4. Trogdor
    Jerry was kind enough to send me some email after inquiring about the delays.  They are at the finish line but manufacturing time (I assume) is in the weeks not days.
  5. kiwirugby Contributor
    Anyone know what are the dimensions of the JH-3A?   I sent Jerry an email last week, but so far no reply.  Hopefully it means he's hard at work on getting out the JH-3As!
    Sorry if this information is elsewhere, but my cursory attempts at finding the dimensions have been unsuccessful.   Thanks.
  6. Br777
    no one has posted the exact dimensions, though there is a photo in here somewhere of an iphone 3rd gen in what looks like an ottorbox on top of a jh3a, which helps give you an idea.   basically the jh3a is every so slightly longer, same width and about twice as thick as a 3rd gen iphone...
  7. MikeCD2020
    At the risk of sounding like a complete noob...(which I more or less am !) will it be possible to connect to the 3a with a SPDIF connection ? I am thinking of the digital out of my iMac or the digital out of the Cypher Labs Solo when that is ready.....Thanks Mike
  8. Bina
    You can use coax spdif from Solo, but iMac have optical spdif, which will not work with JH-3a.
  9. MikeCD2020
    So I will need a converter from my SPDIF (iMac) to coaxil optical... that would not be a problem, or that expensive. Thanks
  10. Bina
    You can use usb input.(It should be on jh-3a)
  11. nc8000 Contributor
    As I understand it the iMac has SPDIF optical out while the JH-3A has SPDIF electrical in. I have never heard of an optical to electrical converter but naturally that does not mean it does not exist.
  12. MikeCD2020
    Taken from the JH site:
    Technical Specifications
    1. 2-Channel Analog Input or SPDIF 24/192 Digital
    2. 6-Channel Amplified Analog Output (>100mA per channel)
    3. 3-Way Active Crossover
    4. Digitally Controlled Volume Level
    5. Digitally Controlled Variable Bass Output - 0dB to + 12dB Boost
    6. 32-bit DSP Resolution
    7. Sample Frequency up to 192KHz
    8. 72-bit Accumulators
    9. 300,000,000 MAC/S
    So, I think that the amp has an ordinary SPDIF with 24/192 Digital.......
  13. Bina
    You have two types of spdif, Coaxial and Optical, imack have only optical, but JH-3a will have coaxial.
  14. Trogdor
    I plan on using the HiFace which is great if the driver didn't panic my system so much...
  15. singh
    Doess 3A have USB input, as far a i 've heard they ave just coaxial. I'll have to buy a usb to coaxial converter. is there a qualty factor in the converter also ( I mean its digital)
