aegid
- Jun 26, 2008
Two parts:
Firstly, which will I use more? The JH-3A or the telephoto?
Second, what do I already have? Can my existing headphones/IEMs do the trick? Can my existing zooms handle it?
For me, it'd be the JH-3A even though I already have a JH13. I don't have a use for telephoto that much and the times I do want to use one I get it from a local rental business. My 10-20mm and 24-105mm serve as my general purpose lenses but it'll be up to you whether you need that range and how often you use that range. As far as concerts go it'd depend on what position I would be at. I'd prefer a prime unless there's no way you can get closer and if you've got clearance to bring a D-SLR with you you probably can get closer.
