Thanks for the reply rawrster. I've got no chance of getting that tool in there. The bores are only about 1.5 mm diameter.
JH Audio JH-13 PRO impressions thread
3nenbgumi
- May 10, 2012
Didn't you get one along with the monitors?
Yup. As much use as an ashtray on a motorbike!
3nenbgumi
- May 10, 2012
You should really put it into use once in a while. I would not worry about ear wax if your ears are clean enough to take impressions, but small pieces of skin can accumulate into buildups inside the bores and that's really going to hurt SQ. My ACS T1's channel imbalance was fixed in the past just by changing the filters.
Oh and about the bubble, since it's not inside any of the bores, could it be that it has always been there and you just didn't notice it before? Manufacturing imperfection perhaps?
Yes the bubbles have been there since the get go. I was preoccupied with getting used to fit and SQ so didn't worry too much. Getting to the point where any refit deal expires and I'll be set with them. Paranoia is a terrible thing!
It's a shame that there are no filters of any kind in the 13's.
3nenbgumi
- May 10, 2012
Now that you've seen them, there's no going back
Poimandres
- Dec 23, 2009
The tool will fit in there, just push it in gently it will compress. Mine has bubbles as well, all of my ciems have had them.
Well you are right. It will fit! Still reckon it's going to push crud down rather than hook it out. I don't know if my ear canals are unusually small. Out of interest what diameter are the bores on your JH?
I was only a bit concerned by the bubbles because they are so close to the bores.
Poimandres
- Dec 23, 2009
My canals are scrawny as well. I thought all of the jh13's were the same diameter. I usually tip them upside down while cleaning them.
I'm probably fretting about a non problem.
kiff
- Apr 14, 2005
If I lose a lot of bass when I listen lying down is this normal or do I need a refit?
Poimandres
- Dec 23, 2009
Lying down puts different stress on your canals. You should feel that.
kiff
- Apr 14, 2005
So a refit would be pointless?
Well my 13's don't lose seal whatever my listening position. Maybe you have a less than perfect fit. How much of an issue that is depends on how much listening you intend to do lying down.
