JDS Labs C5/C5D (pg96) portable amp/amp+DAC
Apr 24, 2016 at 6:58 AM Post #3,316 of 3,417
JDS labs has a post on their Facebook page for a USB type c to type a connector to get their DACs working with USB type c phones. I don't see why a USB type c to USB mini wouldn't work.
https://m.facebook.com/story.php?story_fbid=1138155332871915&substory_index=0&id=213109922043132
Sent from my Nexus 5 using Tapatalk
Seems like they have just rolled out a usb c to mini b cable
https://www.jdslabs.com/products/164/usb-cable-type-c-to-mini-b-otg/
Apr 24, 2016 at 10:13 PM Post #3,317 of 3,417
Has anyone had a chance to compare the c5d and mojo ? Especially when paired with the Shure se846s ?
I prefer the Mojo to my o2/odac combo, and I prefer my o2/odac to the c5d. But the price difference is too much.
Apr 29, 2016 at 9:57 AM Post #3,318 of 3,417
Was going to come here to post if the C5D would work with the SE846, I'm moving up to from the SE535. I bought my C5D earlier this month, because I'm unhappy with the audio on my Nexus6p (was using Viper4Android on my Note2, but don't plan to root my 6p). The C5D and SE535 are great together. Glad to read that the SE846 should be a fine as well. I'm assuming this because the more recent C5D's have a lower imepedance to match.
May 1, 2016 at 1:12 AM Post #3,324 of 3,417
Agreed.
I've heardthe C5D described as neutral with a touch of warmness. I think that's about right.
+1, just a bit warm of what I would consider neutralish.
May 1, 2016 at 2:40 AM Post #3,326 of 3,417
  How is the bass boost experience? I am bass biased so hoping this would be good enough to shake the Fostex to a decent level.
It's a pretty big boost - you can see for the C5D here on low gain: http://blog.jdslabs.com/wp-content/uploads/2013/10/C5D-Bass-Boost-Curves-Low-Gain.png   here on high gain: http://blog.jdslabs.com/wp-content/uploads/2013/10/C5D-Bass-Boost-Curves-High-Gain.png
IDK how it would do with Fostex- over on the Hardest Hitting Headphones thread, when I asked, general opinion seemed to be that JDS C5D is a bit underpowered for maxing out bass with some of their preferred full size cans- guess it depends how far you take it. Might ask over there if you haven't already.
May 2, 2016 at 2:08 AM Post #3,327 of 3,417
C5d is sligthly warmer than the c5. I think t would have enough power. Buy a used one. They are a good value and such good quality that it's safe to buy one used. I have one for sale in the classifieds! (Shameless plug)
Jul 28, 2016 at 7:17 AM Post #3,329 of 3,417
Guys
Is there anyway to output just the DAC signal (un-attenuated)?
Hiya, no, I'm afraid there is no line out on the C5D. It's AMP or DAC/AMP only, which is a shame. They could have implemented it by maxing the volume which then switches off the AMP section and leaves the headphone out as a line out, as I've head of this on others, but unfortunately they didn't :frowning2:
I hope this helps
