Japan-based Head-Fiers & power conditioning
Jul 24, 2005 at 4:25 AM Thread Starter Post #1 of 9
Jim_T
This is somewhat related to a previous post about voltage in Japan and grounding. Does anyone living here in Japan use any kind of power conditioning? All of my stuff (stereo- and computer-related) is running off of two run-of-the-mill multi-outlet power bars. I'm wondering if actual power conditioning (such as Monster PS1000, ONEAC, etc.) would improve sound quality in any way. I don't have high-end stuff, just my home rig (which I can't really turn up anyhow) and a Headamp GS-1 amp with a Headroom Micro DAC on the way. I figure power conditioners from N. America won't do much good here if not properly grounded in a three-prong outlet, so where does that leave us? Does anyone have any of the Audio Technica power outlets? What are YOU using?
Jul 24, 2005 at 4:48 AM Post #3 of 9
Actually, only a few plugs have a real ground. The outlet in my bathroom where the washing machine plugs into has a small screw where you attach the ground wire from the machine. Otherwise, outlets are two prong and they don't accept three pronged plugs. You can get a three-pronged outlet bar but it comes with a ground wire that you're supposed to attach to a proper ground. Not too sure about building my own ...
Jul 24, 2005 at 1:53 PM Post #4 of 9
You are right. Almost all of Japanese houses have been equipped with only 2P plug and no earth plug.
Many Japanese Hi-Fi audiophiles change it to 3P type but it is rare case.
But I do not use the power conditioning which you have mentioned, so I can not comment on it, sorry about this.
Jul 25, 2005 at 6:03 AM Post #6 of 9
Originally Posted by Sinbios
Does the outlet not have a hole for it, or is the wire unavailable altogether? If it's the former case, you can probably buy a new grounded outlet and install that instead.
Problem is that only works if there is a ground wire ran to the outlet. You would probably have to also install a new run from the box.
Jul 27, 2005 at 10:09 AM Post #7 of 9
Unfortunately I'm in a rented apartment and have no knowledge of things electrical. I guess I won't be bothering with fancy power conditioners and such until I move. Thanks everyone.
Jul 27, 2005 at 7:44 PM Post #8 of 9
sorry to jack your thread Jim_T, please excuse my indulgence
Sinbios, how did you like KOTOKO's new album? Glass no Kaze that is, the one that came out on June 8th.
