Is there anything I can do to make vocals sound more forward, without being artificial sound on my AKG K540?
post-10239561
Thread Starter
Post #1 of 5
dakanao
http://en.goldenears.net/9893
They have great clarity, naturalness, good detail retrieval, and good separation, but the vocals are a little recessed. I tried pushing the 250 hz and 500 hz up, and that does make the vocals sound more forward, but then they sound very artificial. So is there anything I can do to make the vocals more forward, but without being artificial sound? Cus they sound very natural and clear, only a little recessed, which makes me have a hard times listening to music.
post-10255204
Post #2 of 5
LFF
Co-Organizer for Can Jam '09
Member of the Trade: Paradox
You can remaster the actual source material. It's common when you have a bad mix or when dealing with certain modern mastering techniques.
post-10255905
Post #3 of 5
dakanao
The songs that had this problem were FLAC files, and they're almost perfectly remastered, if not perfect.
post-10257053
Post #4 of 5
LFF
How do you know they are perfectly remasterd?
If they are indeed perfectly remastered, then that shows you the headphones aren't accurately representing the perfectly remastered music or something else in your chain is greatly affecting your source files in a negative way.
post-10259596
Post #5 of 5
dakanao
Yeah true, the vocals are a little recessed, and they're a tad bit too bright. I have IDT High Definition audio codec onboard soundcard.
