Is There Anything Better Than My Vision:M 60GB?
Jan 6, 2008 at 1:09 PM Thread Starter Post #1 of 6
Big Kev
I've had this for a while now and since I've started using my 500PTH's, I've noticed some break up in the sound every now and then, so am thinking about upgrading, but is there anything out there that's maybe a bit thinner/lighter, as good in the video playback department, at least as good soundwise (with wma support) and at least 30GB?
Jan 6, 2008 at 4:59 PM Post #3 of 6
How loud are you running those things?
I ask because I use a ZVM with E500 and I can't get any clipping out of the amplifier even at dangerous (to your hearing) volume levels. Are you using bass boost or a lot of bass EQ or something?
Jan 7, 2008 at 1:56 AM Post #5 of 6
I'm not sure what you mean by 'sound goes'..?
You might try skipping the bass boost and instead boosting the lowest frequency range in the custom EQ. Using EQ works much better than the bass boost feature.
Jan 7, 2008 at 1:16 PM Post #6 of 6
If you do not need the 30 GB you should get the iAudio7. I have listened to it with your headphones and it sounded perfecto to me..
