audioandy
- Apr 24, 2013
The Aeons (all models, as far as we know) have a well known issue with the pads. The foam under the leather of the pad rolls out of shape, causing the pads to bulge in unexpected ways.
If it's not clear what you're looking for: look for the sharp seams in the leather that don't line up with the stitching on the pads. This is the block of foam inside the pad twisting around. The pads should also look like they're extruding straight of the cups, look for bulging or weird angles of the pad.
This is a pretty bad design flaw, because:
It's also pretty common to see one cup bulge worse than the other. The seams/bulging also appear in random places, as the foam twists unexpectedly. Cups no longer sit flush, and the headphone sits unevenly on your head.
If you're curious, it also affects the Dekoni replacement pads:
In fairness, a minority of users (based on images I see online) get lucky and don't have pad issues. Also some users don't mind the rolling, even though it can affect comfort and seal. Some users even flat out deny this is a real issue, which is funny, because Dan had to make a video explaining how to try to fix this issue. (By the way, myself and others have reported this fix doesn't work, and the foam rolling can be permanent).
Some users report they have to roll the foam back into place every time they use their Aeons. To me, this is an unacceptable design flaw for "high end" headphones. This issue affects all Aeon pads, even the nearly $900 Noir.
Except! Something happened recently!
Dan recently posted this comment in response to a user complaining about the pads after their replacement pads started bulging immediately:
After years of claiming the pad issue is "within tolerance," DCA finally decided to acknowledge and address the core issue! Is #padgate finally over?
I have some questions about this:
- This changes the pad shape, affecting comfort and seal, which can affect the sound
- The change can be permanent
- The change happens unusually quickly to Aeons, some buyers have reported this happening out of the box! For others the permanent pad deformation can happen as fast as 1-2 weeks of use.
- All headphone pads degrade over time, but no other headphone I've owned has bulging pads due to the material inside the pad rolling around, and never this quickly. This is a uniquely weird design flaw.
- The Aeons are sold at a luxury price point, making this an unacceptable design flaw. No one cares about crappy Audiotechnica pads, because they don't cost $500. Also Audiotechnica pads don't have this issue lol.
We have added an adhesive to reduce roll of the foam and also increased foam density within the fabric, both of which should help with longer term stability.
- When do the corrected pads become available, on what Aeon models, and how do we know if we're ordering the defective pads or the corrected ones?
- Even though DCA claims the pad rolling is "within tolerance," they clearly acknowledge it's a warranty issue if you email them, and send you replacement pads (you should do this if you're affected!). Since this is a warranty issue, are existing Aeon users eligible to get a free replacement of the new pads?
- Does this mean we SHOULDN'T leave glue bottles at the DCA booth at CanJam to encourage Dan to fix an issue that doesn't affect any other known headphone pad?
