Originally Posted by MessierObject
Yes there is such a format, being goosed along by Intel, to further their plans to make computers a significant part of a sound/media system. It's called 'Azalia', and will be integrated into their upcoming chip sets.
Its specs include 32-bit resolution with a 192KHz sample rate. Not bad, if this comes to pass as a normal part of a home computer. Not good, if you fear the encroachment of the Evil Empire and the other Winteloids even further into our lives....
For more details Google 'Azalia Intel Audio'.
Better google for High Definition Audio - Azalia only was the codename for the development... Anyway, HDA is not an audio data format as such. It's a standard for the underlying hardware - a modern beefed-up successor of AC'97 2.3, if you will, allowing jack-sensing and -retasing for the audio jacks, for example (well, at least the front panel jacks, actually...). However, HDA doesn't tell you what audio data format to use - it just ensures better electrical implementations and brings the capabilities for high resolution data formats like DVD-A or 24bit/192kHz PCM WAVs.
Going together with HDA is Microsoft's introduction of a new uniform audio driver model called UAA (Universal Audio Architecture) and Dolby's Dolby in PC initiative, which will bring system-wide support for technologies like Dolby Digital, ProLogic IIx, Headphone & Virtual Speaker (whether that's decoding only or also includes encoding support depends on the type of license - Dolby provides three different types with different logos).
There's a lot of confusion potential with all this new stuff. For example, as tkam already mentioned, having HDA doesn't mean you'd get 32bit/192kHz dacs and adcs - it's only the internal resolution of the codec chips. More likely, you'll find 24bit/192kHz converters with the remaining 8 bits providing some digital headroom for mixing several streams together. That you'll be able to get a Dolby labeled pc with HDA also doesn't mean that competitors like Creative, Terratec, M-Audio et cetera wouldn't be able to provide UAA drivers and get a Dolby in PC label license as well.
You can find out a bit more about the codecs over on
www.realtek.com.tw, btw. Interestingly enough, they not only have the 8-channel-version ALC-880, but also a stereo version (ALC-260). There will also be other competitors in the market - I haven't found any info about C-Medias upcoming CMI9880 on the web yet, though.
Personally, I'm still waiting for Intel to provide the specs (which they had already promised several months ago - and the Intel press guys are still working on it... *sigh*). So far, I could only dig up a preliminary hardware spec for a planned mobile HDA module - but if that's anything to go by, there'll only be a 24 MHz clock. That is a rather bad sign, because that probably means one won't be able to get non-resampled Redbook playbook out of HDA codec chips. Souldn't be as bad as with AC'97, though - because 24bit/192kHz could at least ensure the possibility of good quality Redbook upsampling...
Greetings from Hannover!
Manfred / lini
P.S.: I hope that stuff didn't bore you...
