It's generally good practice not to run a transformer above 80% of rated value, as for "oversized", that's pretty meaningless and can be detrimental as the larger the transformer, the more interference it leaks.
Good point. But I'd run the PSU in its own faraday cage, and both the Spitfire and 01USD also have their own...anyway, yes I guess I could get away w/ a 0.3A transformer instead of 0.5A for the Spitfire.
Don't worry about it too much..
Its like if I were trying to decide if I wanted to eat a .32lb hamburger or a .35lb hamburger. First off, It doesn't really matter much, and second off, you're not going to find a hamburger in those exact sizes. Find & use the closest one you can find.
iirc, faraday cages are designed to work for rf interference... not the low-frequency magnetic interference you'll see from a transformer.
The distance between the components will effectively keep the noise out.
