James63
- Oct 24, 2004
Ok, It was the volume control of the line-out that confused me.
Originally Posted by Mr Iriver The iRiver's hardware has separate pins for line level signal. The Philips UDA1380TT chip does work for both true lineout and headphones out. You may want to read this: http://www.fixup.net/talk/topic.asp?TOPIC_ID=791 . As you can see the lineout is actually a true lineout. As other have mentioned if you use the player with no equalizer, and full volume, the signal will be basically untouched. Also remember that the chip of both the H100 series and the H300 series is the same. So both h100 and h300 have a true line out. |
