iswinter
- Apr 13, 2009
I'm not sure if you're still active on this thread. but i'm one of the many with the headphone jack issue. i opened it up. and one of the screws was out, so i screwed it back in and closed it up. the problem wasn't fixed. so my next step is to check that c-shaped grip and try and make it tighter. before i do it, i was wondering if you, or anyone else who reading this who knows, can give me any tips on not messing the jack up more. i didn't remove or look at the inside of the jack when i took it apart previously. any advice is greatly appreciated. thanks in advance!
-AK
Originally Posted by Aevum /img/forum/go_quote.gif there are tons of ipod disassembly guides around, i suspect its one of 2 things, the jack usualy is C shaped on the inside, the main problem is that when a cheap jack is used or too much stress is applied to to the jack, that C expends and dosnt manage to get a decent grip on the headphone jack, solution : press on the C shaped grip to compress it a bit, should solve the issue, or bad soldering/constant stress have damaged the solder points of the part, so you will need to repass the solder points and make sure theres no cracks in the pcb, |
-AK
